16.10.2008, 00:05 | #1 |
Solutions Monkey: Disabling Bound Fields through code
Источник: http://blogs.msdn.com/solutions/arch...ough-code.aspx
============== You can make a bound field as read only or hide the Lookupbutton of the bound field through code in the page load event. For example ... AxBoundField boundField = AxGridView1.Columns[i] as AxBoundField; boundField.ReadOnly = true; ... or ... AxBoundField boundField = AxGridView1.Columns[i] as AxBoundField; boundField.LookupButtonDisplaySettings = LookupButtonDisplaySettings.Never; ... If they do want to hide the lookup for specific rows, then they should use a template field instead of the AxBoundField. For example , In the below code DataSet Name is DemoSet, Table Name is Table1 and FieldName is AccountNum asp:TemplateField ConvertEmptyStringToNull="False" HeaderText="" SortExpression="AccountNum"> Code Behind to hide the lookup control conditionally and disable the cell protected void AxGridView1_RowDataBound(object sender, GridViewRowEventArgs e) { if (e.Row != null && e.Row.RowType == DataControlRowType.DataRow) { /* disable the thrid column which displays accountnum and hide the lookup if the second field value is 1 DataSetViewRow dataRow = (DataSetViewRow)e.Row.DataItem; bool isInternalProject = dataRow.GetFieldValue("Field2").ToString() == "1"; if (isInternalProject) { Control c = e.Row.Cells[2].FindControl("AxLookup1"); if ( c!= null) c.Visible = false; e.Row.Cells[2].Enabled = false; } } ============== Источник: http://blogs.msdn.com/solutions/arch...ough-code.aspx
