palleagermark: Setting up E-mail parameters on the AX 2009 VPC July 2008 image
Источник: http://palleagermark.blogspot.com/20...n-ax-2009.html
============== In order to send e-mail within this image, you need to setup SMTP parameters in AX: Go to Administration / Setup / E-mail parameters: Default in the form you'll find the follwing settings: SMTP port number: 25 Attachment size limit (MB): 10 Enter the following new values: Outgoing mail server: contoso.com Local computer name: dynamicsvm And here is a small job to see if mail can be send: X++: static void testMail(Args args) { SysMailer sysMailer = new SysMailer(); ; sysMailer.quickSend("administrator@contoso.com", "administrator@contoso.com", "Suject", "Body"); } Источник: http://palleagermark.blogspot.com/20...n-ax-2009.html
