Старый 26.04.2009, 00:05   #1
25,643 / 848 (80) +++++++
Dianne Siebold: AIF File Adapter Processing Sequence
Источник: http://blogs.msdn.com/dsiebold/archi...-sequence.aspx
When you use the AIF file adapter to process messages, you might think that the messages would be processed sequentially in the order they are submitted as determined by the file time stamp (even though the processing is asynchronous). But the file adapter actually uses the file name and processes the messages alphabetically.
So if you want to control the order in which messages are processed by the file adapter, you can do so by creating a sequence using the file name. For example, file names such as PO_000001.xml, PO_000002.xml, and so on. You get the idea. You could potentially create any type of sequence you want.
blog
Dianne Siebold: AIF BizTalk Adapter White Paper Updated for 2009 Blog bot DAX Blogs 0 31.01.2009 11:05
Dianne Siebold: Video About the AIF Services and WCF Blog bot DAX Blogs 0 11.10.2008 07:43
Dianne Siebold: AIF Code Samples Available for Download Blog bot DAX Blogs 0 22.08.2008 09:05
Dianne Siebold: AIF Top Ten Blog bot DAX Blogs 1 22.04.2008 11:19
Часовой пояс GMT +3, время: 15:50.
