gatesasbait: Dynamics Ax 2009 SSRS report deployment under Server 2008
Источник: http://gatesasbait.spaces.live.com/B...B9F5!314.entry
============== If you get the following error in the deployment log file: “Deployment failed with the following exception: System.Runtime.InteropServices.COMException (0x80040208) at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo) at System.Management.ManagementObject.Initialize(Boolean getObject) at System.Management.ManagementBaseObject.get_Properties() at System.Management.ManagementBaseObject.GetPropertyValue(String propertyName) at Microsoft.Dynamics.Framework.Deployment.Reports.SrsWmi.get_ConfigPath() at Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployBusinessLogicAssemblies(IEnumerable`1 businessLogicAssemblies, DeploymentLogger logger) at Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.Deploy(IEnumerable`1 reportLibrariesToDeploy, IEnumerable`1 transitiveReferenceClosure, IEnumerable`1 cultures, DeploymentLogger logger, Func`2 connectionStringModifier)” You just need to disable the UAC (User Account Control), or to run the Deployment tool with right-click “Run as administrator”. As it says in the Dynamics AX installation guide. Duh… Источник: http://gatesasbait.spaces.live.com/B...B9F5!314.entry
Теги |
blog, ax2009 |
