08.05.2008, 22:06 | #1 |
axStart: InfoPath with default AIF web services
Источник: http://axstart.spaces.live.com/Blog/...C0A0!310.entry
============== Introduction When completed this session you have created an InfoPath form that can interact with a Microsoft Dynamics AX Web service. On the end of this document we will use Microsoft Visual Tools for Applications for automatically generate GuidID and Source Endpoint User ID. Also enhancements to the AxdClass will be made. Create a web service in AX
NOTE: only Tables with a unique primary index will work correctly in AIF when you want to find, delete or update the record. Creating the related classes
Change class AxdProjHours method prepareForSave This method is used for additional programming logic. In our casem we have to create a journal. We decide to make a journal for every week. public boolean prepareForSave(AxdStack _axdStack, str _dataSourceName) { ProjJournalTable projJournalTable; JournalID journalID; axProjJournalTrans axProjJournalTrans; ; switch (classidget(_axdStack.top())) { case classnum(AxProjJournalTrans) : axProjJournalTrans = _axdStack.top(); //InfoPath Demo create journal in case not exist journalID = strfmt("Week %1",wkofyr(axProjJournalTrans.parmProjTransDate())); if(!ProjJournalTable::exist(journalID)) { projJournalTable.initFromProjJournalName(ProjJournalName::Find("Hour")); projJournalTable.JournalId = journalID; projJournalTable.insert(); } axProjJournalTrans.parmJournalId(journalID); //InfoPath Demo create journal in case not exist return true; default : error(strfmt("@SYS88979",classId2Name(classidget(_axdStack.top())))); return false; } return false; } Create the new Web service
Create a new Endpoint for the action with additional authorization.
[/FONT] Create an InfoPath document Open InfoPath 2007 on the VPC. Select design a Form Template. Select Web Service and press OK. InfoPath will open a wizard that helps you to find and connect the right way to our AIF ProjHours Web Service. In our case we will Submit Data. The web service is located at http://dynamicsvm/DynamicsWebService/ProjHoursService.asmx. InfoPath will show a list of operations that will submit data. We can only select our creareListProjHours operation. We don’t change the name of this web service because it is still our main submit. Designing the Form Drag the fields to the form that you need. First we drag the DocumentContext node to the design. When dropping it into the design we select ‘Controls in Layout Table’ Next select the end of your document and press Insert/repeating Table. Select the ProjJournalTrans record and press next. Select the fields that are needed for the InfoPath dialog and press Finish Finally give the CurrencyID a default value EUR , by double clicking on the CurrencyID of the datasource and entering the value. Programming in InfoPath We have the general design for our InfoPath dialog available, but we don’t have match intelligence. It would be better if we dynamical generate:
Go to the FormEvents_Loading method and add these lines of code: public void FormEvents_Loading(object sender, LoadingEventArgs e) { string xmpPath = "/dfs:myFields/dfs:dataFields/tns:createListProjHours/tns:DocumentContext"; XPathNavigator xmlGuid = this.MainDataSource.CreateNavigator().SelectSingleNode(xmpPath +"/tns:MessageId", this.NamespaceManager); XPathNavigator xmlEndPointUser = this.MainDataSource.CreateNavigator().SelectSingleNode(xmpPath +"/tns:SourceEndpointUser", this.NamespaceManager); XPathNavigator xmlSourceEndpoint = this.MainDataSource.CreateNavigator().SelectSingleNode(xmpPath + "/tns:SourceEndpoint", this.NamespaceManager); XPathNavigator xmlEndPoint = this.MainDataSource.CreateNavigator().SelectSingleNode(xmpPath + "/tns:DestinationEndpoint", this.NamespaceManager); xmlGuid.SetValue(System.Guid.NewGuid().ToString()); xmlEndPointUser.SetValue(System.Environment.UserDomainName + "\" + System.Environment.UserName); xmlSourceEndpoint.SetValue("Hours"); xmlEndPoint.SetValue("dmo"); } Next Build (compile) your solution in Visual Studio. Close Visual Studio and do your first test in InfoPath by pressing the Preview button. And ……….. we get an error! This error tells us that we are not allowed to check for the user and domain name. Think about secure x++ code you have to ask permission for it. So let’s ask for permission. Close the preview and go back to visual studio and add next line in the FormEvent_loading method new EnvironmentPermission(PermissionState.Unrestricted).Assert(); Also add the library for this Class at top of your c# project using System.Security.Permissions; Now the code is ready for secure coding but our InfoPath Form is not trusted jet. To get our InfoPath trusted, do the next steps:
EmplID RAV ProjID 40010 CategoryID Install Qty 8 LinePropertyID Charge Testing, debugging & fixing If you submit your data and you get an error. The information of this error is a little bit incomplete. Detailed information about the error is available in AX. Look at the Form at Menu/Basic/Periodic/AIF/Exceptions. NOTE AIF will skip fields when the property allowEditOnCeate is set to NO, without any warning Good luck for dowloading the solution: Code + article in pdf format What’s Next Next week we will redesign our InfoPath form so it can interact with AIF file inbound adapter. In the final week we will introduce offline working and automatic synchronization and add lookup fields for selecting project, Employee etc. Источник: http://axstart.spaces.live.com/Blog/...C0A0!310.entry
15.05.2008, 02:27 | #2 |
axStart: InfoPath with default AIF file inbound
Источник: http://axstart.spaces.live.com/Blog/...C0A0!322.entry
============== Introduction Last week we used an AX Web service in combination with InfoPath. The solution we build had still some limitations. This week we will create an InfoPath Document that post documents to the AIF inbound file adapter. There is no difference on user experience when he posts to a web service or the AIF File inbound adapter. Create a file inbound service in AX We can reuse all Axapta code from the previous session, but I make some additional enhancement on them. Till now, the created ProjJournalTrans records where nicely, but if we look more closely on it; it’s not as beautiful as expected. A lot of fields where not set:
public boolean prepareForSave(AxdStack _axdStack, str _dataSourceName) { //TODO: Remember to make code for validating fields that are added to the initMandatoryFieldsMap method // that are not mandatory in the table ProjJournalTable projJournalTable; JournalID journalID; axProjJournalTrans axProjJournalTrans; ProjJournalTrans projJournalTrans; ; switch (classidget(_axdStack.top())) { case classnum(AxProjJournalTrans) : axProjJournalTrans = _axdStack.top(); journalID = strfmt("Week %1",wkofyr(axProjJournalTrans.parmProjTransDate())); if(!ProjJournalTable::exist(journalID)) { projJournalTable.initFromProjJournalName(ProjJournalName::Find("Hour")); projJournalTable.JournalId = journalID; projJournalTable.insert(); } axProjJournalTrans.projJournalTrans().initFromProjTable(ProjTable::find(projJournalTrans.ProjId)); axProjJournalTrans.projJournalTrans().setTransDate(); axProjJournalTrans.setFieldAsTouched(fieldnum(projJournalTrans,dimension)); axProjJournalTrans.setFieldAsTouched(fieldnum(projJournalTrans,CostPrice)); axProjJournalTrans.setFieldAsTouched(fieldnum(projJournalTrans,salesPrice)); axProjJournalTrans.setFieldAsTouched(fieldnum(projJournalTrans,PeriodDate)); axProjJournalTrans.setFieldAsTouched(fieldnum(projJournalTrans,TaxGroupId)); axProjJournalTrans.setFieldAsTouched(fieldnum(projJournalTrans,TaxItemGroupId)); axProjJournalTrans.setFieldAsTouched(fieldnum(projJournalTrans,CategoryId)); axProjJournalTrans.setFieldAsTouched(fieldnum(projJournalTrans,TransDate)); axProjJournalTrans.parmJournalId(journalID); //TODO Put validating code for ProjJournalTrans here return true; default : error(strfmt("@SYS88979",classId2Name(classidget(_axdStack.top())))); return false; } return false; } NOTE: Changes on table fields without using the ParmFIeldName method need an addition setFieldAsTouched call, otherwise the changes are lost. Create the new file inbound service We will reuse the existing file Inbound adaptor of the Contoso VPC (c:\AIF\Inbound). The InfoPath document will post the xml messages in this map and AX AIF Batch will process them. It is also posible to process the messages with below x++ job. static void AifReceiveSend(Args _args) { ; // receive documents in inbound processing queue and process new AifGatewayReceiveService().run(); new AifInboundProcessingService().run(); // create documents in outbound processing queue and process // new AifOutboundProcessingService().run(); // new AifGatewaySendService().run(); } NOTE: Change class AifInboundProcessingService method run for debugging purpose. You have to replace the runas(……) code with AifInboundProcessingService::processRequest(message); After debugging your AIF inbound process can gets corrupted. In that case you have to clean up manually the table AifResourceLock & AifGatewayQueue Before we can connect InfoPath to the file inbound adapter, we have to get all XSD information.
Create an InfoPath document Open InfoPath 2007 on the VPC. Select design a Form Template. Select XML or Schema and press OK. InfoPath will open a wizard that helps you to find and connect the right way to the XSD of ProjHours. The main XSD is the message.XSD. Select this one from C:\Program Files\Microsoft Dynamics AX\Application\Share\Include
From this point we have an InfoPath form with data source that can do the job. Designing the Form
Our InfoPath design will looks like: Programming in InfoPath We have the general design for our InfoPath dialog available, but we don’t have match intelligence. It would be better if we dynamical generate:
Go to the FormEvents_Loading method and add these lines of code: public void FormEvents_Loading(object sender, LoadingEventArgs e) { string guidID = System.Guid.NewGuid().ToString(); XPathNavigator root = this.MainDataSource.CreateNavigator(); root.SelectSingleNode("/ns1:Envelope/ns1:Header/ns1:MessageId", this.NamespaceManager).SetValue(guidID); root.SelectSingleNode("/ns1:Envelope/ns1:Header/ns1:SourceEndpointUser", this.NamespaceManager).SetValue(System.Environment.ExpandEnvironmentVariables("%userdomain%\%username%")); root.SelectSingleNode("/ns1:Envelope/ns1:Header/ns1:SourceEndpoint", this.NamespaceManager).SetValue("ProjHours"); root.SelectSingleNode("/ns1:Envelope/ns1:Header/ns1:DestinationEndpoint", this.NamespaceManager).SetValue("DMO"); root.SelectSingleNode("/ns1:Envelope/ns1:Header/ns1:Action", this.NamespaceManager).SetValue("createListProjHours"); } Next Build (compile) your solution in Visual Studio. Close Visual Studio and do your first test in InfoPath by pressing the Preview button. And ……….. we get an error! This error tells us that we are not allowed to check for the user and domain name. Think about secure x++ code you have to ask permission for it. So let’s ask for permission. Close the preview and go back to visual studio and add next line in the FormEvent_loading method new EnvironmentPermission(PermissionState.Unrestricted).Assert(); Also add the library for this Class at top of your c# project using System.Security.Permissions; Now the code is ready for secure coding but our InfoPath Form is not trusted jet. To get our InfoPath trusted, do the next steps:
public void FormEvents_Submit(object sender, SubmitEventArgs e) { try { string filepath = "\\Dynamicsvm\Inbound\"; string file = System.Guid.NewGuid().ToString() + ".xml"; XmlDocument soapXML = new XmlDocument(); soapXML.Load(this.MainDataSource.CreateNavigator().ReadSubtree()); XPathNavigator soapXMLnav = soapXML.CreateNavigator(); new FileIOPermission(FileIOPermissionAccess.Write, filepath + file).Assert(); soapXML.Save(filepath + file); e.CancelableArgs.Cancel = false; } catch (Exception) { MessageBox.Show("aif message is not stored"); } } Preview your InfoPath form again and test the web service with next data EmplID RAV ProjID 40010 CategoryID Install Qty 8 LinePropertyID Charge Testing, debugging & fixing If you submit your data and you get an error. The information of this error is a little bit incomplete. Detailed information about the error is available in AX. Look at the Form at Menu/Basic/Periodic/AIF/Exceptions. Good luck article in PDF format + code download What’s Next Next week we will create lookups and make offline working possible. Источник: http://axstart.spaces.live.com/Blog/...C0A0!322.entry
Теги |
aif, axbc, webservice |
