Старый 22.05.2009, 01:05   #1
Solutions Monkey: Inside Microsoft Dynamics AX 2009 book RTM'ed
Источник: http://blogs.msdn.com/solutions/arch...ok-rtm-ed.aspx
http://blogs.msdn.com/microsoft_pres...s-ax-2009.aspx
I wrote two chapters in Inside Dynamics AX 2009 book about Enterprise Portal and Role Centers. I also contributed to the Architecture Chapter and upgrade. Thanks to the entire EP team who implemented these great features and contributed in many ways to the content of these chapters. These chapters have wealth of info for developers and I would recommend strongly for EP / Role Center developers :) :) .
Старый 22.05.2009, 01:05   #2
Arijit Basu: Inside Microsoft Dynamics AX 2009 has RTM'ed today :-)
Источник: http://daxguy.blogspot.com/2009/05/i...-2009-has.html
The 2nd book from Microsoft Press on Microsoft Dynamics AX has RTM'ed today and is available on Amazon to preorder. As per sources, this book will be available from June 10th onwards. I had a small involvement in this book and I recommend this to all AX 2009 developers. This is a must read if you want to get your fundamentals cleared. Lots of detailed information on AX 2009 Architecture, EP & Role centre, Workflows, AIF, Performance and so on. Click on the image below to preorder.
Старый 22.05.2009, 09:09   #3
miklenew is offline
miklenew
Аватар для miklenew
1,688 / 438 (18) +++++++
Интересно, а что нарисовано. Стилизованный кастет.
Старый 22.05.2009, 09:15   #4
Bober is offline
Bober
311 / 104 (4) +++++
Это бритва.
Сначала Аксапту хотели причесать, но этого оказалось мало.
Затем решили побрить наголо, и так брили, и этак, и хотя всё равно бритву с обеих сторон обломали, всё получилось гладко (см.фон) - нигде ничего не торчит.
Старый 22.05.2009, 12:46   #5
fed is offline
fed
Аватар для fed
2,913 / 5736 (197) ++++++++++
А по моему - это ручка без чемодана. Резиновая такая - из черной резины. Без которой чемодан выбросить жалко, а нести - тяжело.
Старый 22.05.2009, 18:27   #7
raz is offline
raz
NavAx
Аватар для raz
NavAx Club
1,497 / 1096 (39) ++++++++
Это знаменитая Бритва Оккама
Старый 26.05.2009, 15:25   #8
Evgeniy2020 is offline
Evgeniy2020
309 / 68 (3) ++++
это денежный Скребок,
чтобы можно было наскребсти побольше денег.
Старый 31.05.2009, 12:15   #9
ZornFire is offline
ZornFire
MS Dynamics AX 2012 R3
Аватар для ZornFire
Oracle
333 / 76 (3) ++++
обложка это конечно хорошо, а ссылка где скачать книгу эту на русском языке можно, имеется у каго?))
Старый 31.05.2009, 12:20   #10
на русском ее еще нет, насколько я знаю.
работы по переводу только ведутся, насколько я знаю.
переводчиками являются специалисты по аксапте, насколько я знаю.
и насколько я знаю, переводчики форум читают.
поэтому замечания и пожелания к будущему переводу приветствуются.
Старый 02.06.2009, 10:55   #11
natterru is offline
natterru
А ссылку на этот переводческий проект и книгу на английском можно? Есть желание поучаствовать!
Старый 27.07.2011, 16:24   #12
ivas is offline
ivas
Аватар для ivas
252 / 68 (3) ++++
“tracing profile gauge"
http://www.leevalley.com/us/wood/pag...=1,42936,42958
aLL woRk aNd nO JoY MAKes jAck a dULL Boy
Последний раз редактировалось ivas; 27.07.2011 в 16:26.
За это сообщение автора поблагодарили: gl00mie (1), shogel (1).
Arijit Basu: Managing Your Supply Chain using Microsoft Dynamics AX 2009 Blog bot DAX Blogs 0 13.02.2009 21:05
Arijit Basu: Microsoft Dynamics Snap for Dynamics AX 2009 Blog bot DAX Blogs 0 18.10.2008 19:06
Arijit Basu: Microsoft Dynamics AX 2009 Programming Blog bot DAX Blogs 1 18.02.2008 01:04
Часовой пояс GMT +3, время: 10:41.
