Старый 10.07.2009, 10:05   #1
25,643 / 848 (80) +++++++
Khue Trinh: Fill Utility in AX2009
Источник: http://khue.spaces.live.com/Blog/cns...A0C2!580.entry
If you are using AX2009, you may want to explore a new feature called Fill Utility. This functionality allows you to update a range of records with a value. Basically, I found that this works like using UPDATE T-SQL statement in query analyzer.
An example: I want to change all customers that are using mode of delivery 10 – Truck to 30 - Rail.
Firstly, you need to activate the configuration setting for Fill Utility by going to Administration > Setup > System > Configuration
Under Administration node, you will find the Fill utility node and need to activate this. It may take a while to finish the task with configuration change or synchronization.
Once you have done that, go to the customer master file, right click on the customer, and choose Record Info
Click Fill utility, you will be able to specify the selection criteria you want to filter. Reset the customer account to blank and set the Mode of delivery to 10 and click OK, system will filter the customer list to get your customers.
Enter the new Mode of delivery and think twice then click OK.
Technorati Tags: AX2009,Fill utility
Khue Trinh: Adjust Standard Cost of Item Blog bot DAX Blogs 1 30.04.2008 15:08
Khue Trinh: Set up & perform Global Search Blog bot DAX Blogs 0 26.01.2008 18:22
Khue Trinh: Mass Deployment of the Microsoft Dynamics AX Client Blog bot DAX Blogs 0 07.01.2008 15:51
Khue Trinh: RESERVATION AT A GLANCE Blog bot DAX Blogs 0 07.01.2008 15:51
Khue Trinh: Be careful with Inventory journal Blog bot DAX Blogs 0 07.01.2008 15:51
Часовой пояс GMT +3, время: 12:02.
