hariprasadp: Code for pulling data from other than AX Database of SQL to AX Table
Источник: http://hariprasadp.spaces.live.com/B...B91F!203.entry
============== X++: //HariPattela- code for pulling data from other than AX Database of SQL to AX Table static void SQL_CustPaym(Args _args) { LoginProperty LP = new LoginProperty(); myConnection; myStatement; myStatement1; myResult,myResult1; paymTerm; str tstCustId; ; //DSN - if the data base is on diffrent server LP.setDSN("SqlTestSvr"); LP.setDatabase('newErp'); myConnection = new OdbcConnection(LP); myStatement = myConnection.createStatement(); myResult = myStatement.executeQuery("SELECT * FROM SA_PayTerm"); while (myResult.next()) { = myResult.getString(1); if(!paymterm::find(tstCustId)) { ttsbegin; paymTerm. = tstCustId; paymTerm. = myResult.getString(2); paymTerm. = any2int(myResult.getString(3)); paymTerm.insert(); ttscommit; info(tstCustId); } // myResult1 = myStatement.executeQuery("delete FROM SA_PayTerm "+ "where SA_PayTerm.PaymentCode ="+"'"+ tstCustId+"';"); // _strSQL = "delete from fwcatns_materialmaster " + // "where MaterialId = '" + _InventTable.ItemId + "';"; // while(myResult1.next()) // { // info("Payment Term Id = %1", tstCustId); // } // } } ============== Источник: http://hariprasadp.spaces.live.com/B...B91F!203.entry
