Kashperuk Ivan: Tool: DEV_SysTableBrowser and DEV_CreateNewProject tools now on AX 2009
Источник: http://kashperuk.blogspot.com/2010/0...owser-and.html
============== 3 or so years ago I created a couple of tools that provide extra capabilities for AX developers, specifically, ease up the creation of a new project with a predefined structure and name pattern, and add functionality to the way we browse tables with the standard SysTableBrowser, allowing to specify the exact fields you want to see, browsing temporary tables. Both tools were also available as Tabax plugins You can read more about the tools, as well as Tabax, on the following pages on Axaptapedia: DEV_SysTableBrowser home page on Axaptapedia DEV_CreateNewProject home page on Axaptapedia You can download the new versions of these tools through the pages on Axaptapedia, or directly from my SkyDrive: DEV_SysTableBrowser, DEV_CreateNewProject If you are unfamiliar with these tools, I suggest you go through Axaptapedia, as it also contains a detailed description of the features provided. A couple of things I would like to note:
Let me know if you have comments, suggestions or ideas for these tools. Thanks Источник: http://kashperuk.blogspot.com/2010/0...owser-and.html
Кстати, оказывается, баг с Обозревателем таблиц пофиксили в Hotfix Rollup 3 для АХ 2009.
Я добавил этот код в хро, так что у кого АХ 2009 с хотфиксом, тому повезло. |
За это сообщение автора поблагодарили: gl00mie (10). |
