Старый 07.05.2010, 01:06   #1
25,626 / 848 (80) +++++++
Dynamics CRM Tools: Update: Form Javascript Manager
Источник: http://mscrmtools.blogspot.com/2010/...t-manager.html
Hi all,
It is a long time since I have posted some news on my blog… Well, I have lot of work and have to deal with many CRM projects. Not easy everyday :)
Today, it is not really a tool update, almost a new tool. If you download the latest version of the FormJavascriptManager, you will find a second tool: FormJavascriptManagerCommand.
It is a command line utility that will allow you to automate export and import of your form scripts. Thanks to Bianca for the idea after a presentation of TFS2010 and CRM project automation.
Here are some instructions:
FormJavascriptManager.exe /c /f [/i|/e] [optionalParameters]
Mandatory Parameters:
/c : Name of the connection to use in mscrmtools.config file
/f : Folder where to read and write scripts
/e : Export the scripts of specified entities in (with format entity1;entity2;entity3)
OR
/i : Import the scripts located in the specified folder
Optional Parameters:
/p : Publish the customizations (Must be used with /i parameter)
/pwd : Password when using custom or IFD authentication
/l : Path for the log file
Examples
FormJavascriptManager.exe /c AnIfdConnection /pwd MyPassword /e account;contact;lead /f d:\exportFolder /l d:\logFolder\log.txt
FormJavascriptManager.exe /c OnPremiseConnection /i /p /f d:\importFolder /l d:\logFolder\log.txt
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
Dynamics CRM Tools: Update : Form Javascript Manager Blog bot Dynamics CRM: Blogs 0 14.10.2009 19:05
Часовой пояс GMT +3, время: 01:35.
