Старый 07.05.2010, 01:06   #1
kamalblogs: Vertical Selection in X++ Editor in Dynamics Ax
Источник: http://kamalblogs.wordpress.com/2010...n-dynamics-ax/
Generally in use X++ editor we use line selection or complete block selection to modify the text. In Ax
you can also use vertical block selection to remove spaces or delete text. Here is a small demonstration of vertical block selection along with the way to do it.
За это сообщение автора поблагодарили: casperkamal (1).
Старый 07.05.2010, 09:04   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
"Жмем Alt-O и выделяем вертикальный блок" - где ж ты раньше был?! Оказывается, эта возможность даже в 3-ке есть...
Старый 07.05.2010, 09:20   #3
casperkamal is offline
casperkamal
Hi Gloomie,
Thanks for the comment. But was not able to understand your comment through translators w..can you translate so that i can answer it ?
Старый 07.05.2010, 10:31   #4
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Post
Не забываем назад переключится Shift - O
Старый 07.05.2010, 12:05   #5
casperkamal
Thumbs up
@Poleax I don't think Shift + O is required to switch it off .....
@Kashperuk
Thanks Kashperuk. Very well understood.
I just made it a trial post to see how posts with video works..
moreover lot of programmers i have interacted haven't picked it up (Alt + O)...so just thought would do that....
will help beginners
Последний раз редактировалось casperkamal; 07.05.2010 в 12:11.
За это сообщение автора поблагодарили: Lemming (5), alex55 (1).
Старый 07.05.2010, 22:45   #6
gl00mie is offline
gl00mie
Just to clarify, for casperkamal's sake: There is always a lot of sarcasm on this forum, whenever a "well-known" AX feature is "re-discovered".
Well I must mention there was no sarcasm in my comment. I've been using Far Manager's internal editor for years for some X++ code editing - just to work with vertical blocks (and to work with Perl-like regular expressions, and... well, never mind).
Сообщение от casperkamal Посмотреть сообщение
lot of programmers i have interacted haven't picked it up (Alt + O)...so just thought would do that... will help beginners
Thanks a lot! Now MorhpX code editor doesn't look that hopeless compared to others
Старый 07.05.2010, 10:33   #7
oip is offline
oip
Axapta
2,564 / 1416 (53) ++++++++
Записей в блоге: 1
Gustav: Unsorted, или Записки DAX-дилетанта - II А еще это есть по-крайней мере в Inside Microsoft Dynamics AX 2009 на 70 странице. А в Inside Microsoft Dynamics 4.0 почему-то написано Ctrl+O. Или это был сарказм?
For casperkamal: I wrote that this Alt+O combination is mentioned in the Inside Microsoft Dynamics AX 2009 book on the 70th page. But in the Inside Microsoft Dynamics 4.0 book it is written that this combination is Ctrl+O.
Hi Gloomie,,
He wrote smth like "Wow, why didn't you tell this earlier?! It seems it is working even in DAX 3.0."
За это сообщение автора поблагодарили: Gustav (2).
Старый 07.05.2010, 09:55   #8
S.Kuskov is offline
S.Kuskov
3,448 / 1792 (66) ++++++++
А я знал
На самом деле не так часто эта возможность и восстребована
Старый 07.05.2010, 11:33   #9
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Just so that you read the comments in the correct context.
We are in general very nice people
Developer for Microsoft Dynamics AX Certification Roadmap Blog bot DAX Blogs 1 13.05.2009 16:17
Часовой пояс GMT +3, время: 22:10.
