Старый 15.07.2010, 20:08   #1
kamalblogs: Exists methods don’t need table declaration in Dynamics Ax
Источник: http://kamalblogs.wordpress.com/2010...d-declaration/
Do you know when we use select statement for conditional checks, we don’t need to declare a variable if we use the same name as the table. Look at the example below to understand better.
static boolean SelectStatementInBooleanConditions()
    //no declaration for table object has been made.
    boolean test;     ;
    //testing a variable
    test =  (select firstonly salesTable).salesId ? true : false;
    //if condition
    if ((select firstonly salesTable).recid)
        return true;
    //switch statement
    switch ((select firstonly salesTable).recid)
        case 0:
            return true;
        case 1:
            return false;
    default:
            return false;
    //return statement
    return ((select firstonly salesTable).recid);
In standard you can find similar usage extensively in exists methods. This can make your code smarter and simpler
Run the job and see that you dont get any errors……
Старый 15.07.2010, 20:57   #2
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Интересно, сколько времени потребуется highly skilled technical consultant-у с 5 (согласно профайлу в Linkedin) годами стажа в AX чтобы обнаружить, что это распространяется не только на exists методы?
-ТСЯ или -ТЬСЯ ?
Старый 15.07.2010, 21:13   #3
casperkamal is offline
casperkamal
Sharing it today doesn't meant that i got to know it today vadik
Старый 16.07.2010, 10:28   #4
coolibin is offline
coolibin
264 / 68 (3) ++++
casperkamal, great to see you on this site! How about joining other topics here?
Старый 16.07.2010, 13:52   #5
casperkamal
Thanks for your welcome coolibin... I'll definitely join other threads too
kamalblogs: Virtual Convergence Dynamics Ax — Don’t Miss it !!! Blog bot DAX Blogs 0 03.06.2010 13:05
Developer for Microsoft Dynamics AX Certification Roadmap Blog bot DAX Blogs 1 13.05.2009 16:17
Часовой пояс GMT +3, время: 21:26.
