dynamicsaxtraining: How to check if your variable suit the conditions given in query range
Источник: http://www.dynamicsaxtraining.com/kn...in-query-range
============== Use inRange methods from Global class static boolean inRange(str _rangeValue, anytype _value) Example: { str _rangeValue; str _value ; boolean result; ; _rangeValue = ‘200..500’; _value = ‘300’; result = Global::inRange (_rangeValue , _value);}The result variable will be equal to true Источник: http://www.dynamicsaxtraining.com/kn...in-query-range
