09.12.2010, 02:13 | #1 |
dynamicsaxtraining: How to access field in a table using this field id
Источник: http://www.dynamicsaxtraining.com/kn...-this-field-id
============== To do this you could use next construction: myTable.( filednum( myTable, myField ) ) = “XXX”; This is the same as myTable.myField = “XXX”; Example: Field AccountNum from CustTable have id 1. Then statement CustTable.(1) = “4000” – will initialize field AccountNum with value “4000”. You could also use this feature while working with record of type Common. Example: Common common; CustTable custTable; ; select custTable where custTable.AccountNum == "4000"; common = custTable; info( common.( fieldnum( custTable, Name ) ) );The output of running this code will be the info log with a message “Light and Design”, Where “Light and Design” – name of the customer with id “4000″. Источник: http://www.dynamicsaxtraining.com/kn...-this-field-id
