Старый 21.12.2010, 04:13   #1
25,617 / 848 (80) +++++++
Dynamics AX Sustained Engineering: Performance issue on Query Object when using Outer Join with more than one Child Table
Источник: http://blogs.technet.com/b/dynamicsa...ild-table.aspx
Problem:
Sub-optimalSQL (multiple SQL statements) generated when a query object has more than one child table in the datasources nested directly under the parent table.
Resolution:
Changethe default "fetch mode" from “1:n” to “1:1” while linking the childdata sources to the parents.
Dynamics AX Sustained Engineering: Compatibility Result for Microsoft Application Virtualization - November 2010 Blog bot DAX Blogs 0 09.11.2010 19:10
Dynamics AX Sustained Engineering: Some charts in the Role Center show a wrong axis scale 0-0-0-1-1-1 Blog bot DAX Blogs 0 24.07.2010 04:08
Dynamics AX Sustained Engineering: Upgrade script ReleaseUpdateDB41_Invent\updateInventItemPrice () fails without LogisticsAdvanced license code Blog bot DAX Blogs 0 07.07.2009 03:05
Часовой пояс GMT +3, время: 11:55.
