Старый 25.02.2011, 16:11   #1
25,643 / 848 (80) +++++++
emeadaxsupport: Documentation "How to: Add a URL Drill Through Action" confusing
Источник: http://blogs.msdn.com/b/emeadaxsuppo...confusing.aspx
Recently we found an "Invalid Range" error to logged when using drill through on an AX SRS Report we created for a custom table following the documentation at the link below:
"How to: Add a URL Drill Through Action" http://msdn.microsoft.com/en-US/library/cc582049.aspx
From further investigation we found the the hardcoded 1 at indexFields.Add method from the code below to be the cause. The number is not referencing the order of the fields in the unique (composit) index but is a reference to the fieldnumber of the field in the table. For CustTable accountNumber used in the sample code this appear to be 1. For fields in custom tables this is rarely the case
Just to clear up the confusion.
[DataMethod(), AxSessionPermission(SecurityAction.Assert)]
public static string AccountNumberUrl(string context, string accountNumber)
    Dictionary indexFields = new Dictionary();
    indexFields.Add(1, accountNumber);
    int tableId = 77;     // Check whether the context is the client. If so, generate a
    // URL to display the CustTable form.
    if (RuntimeReportContext.IsClientContext(context))
        return DynaLink.GenerateURL(context, "CustTable", MenuItemType.Display, tableId, indexFields);
     // Check whether the context is EP. If so, generate a URL to
    // display the EPCustTableInfo Web menu item.
    else if (RuntimeReportContext.IsEPContext(context))
        return DynaLink.GenerateURL(context, "EPCustTableInfo", MenuItemType.WebMenuItemTypeUrl, tableId, indexFields);
    return string.Empty;
--author: Jago van der Most --editor: Jago van der Most --date: 25/Feb/2011
emeadaxsupport: How to add financial dimension to Dynamics AX Default cubes Blog bot DAX Blogs 0 13.01.2011 16:11
emeadaxsupport: How to troubleshoot Enterprise Portal error ”Unable to render content due to an error. Please contact your system administrator." Blog bot DAX Blogs 0 17.11.2010 18:11
emeadaxsupport: How can the Web Proxies get extended programmatically? Blog bot DAX Blogs 0 16.12.2009 18:05
Kashperuk Ivan: Running a class from AOT or "How to assign a class to an action menu item?" Blog bot DAX Blogs 0 22.10.2009 20:05
emeadaxsupport: How to fix SQL error: "Too many parameters were provided in this RPC request" Blog bot DAX Blogs 0 01.09.2009 15:05
Часовой пояс GMT +3, время: 12:20.
