Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 2011 Sitemap Changes
Источник: http://blogs.msdn.com/b/crm/archive/...p-changes.aspx
============== Why doesn’t my new custom entity appear in the navigation pane? If you are familiar with Microsoft Dynamics CRM 4, then you know that you can easily add a custom entity to any area in the sitemap navigation. When you select an area in the entity metadata editor, Microsoft CRM automatically modifies the sitemap to create an extra group called “Extensions” in the specified area for your custom entity. In Microsoft Dynamics CRM 2011 changes to the sitemap are not visible until the sitemap is published. This is similar to how forms worked in previous versions. When you create a custom entity and add it to a specific group then you will need to publish the sitemap individually or “publish all customizations.” After publishing you can refresh your browser to see the changes. Why is this group “unknown” showing up after upgrade? If you customized the CRM 4 sitemap by adding a custom sub area to the settings area then you will get a group titled “unknownXX” after you upgrade your server to CRM 2011. ![]() <div style="padding-bottom: 0px; margin: 0px; padding-left: 0px; padding-right: 0px; display: inline; float: none; padding-top: 0px" id="scid:9D7513F9-C04C-4721-824A-2B34F0212519:c4f5ea39-e9c1-4ffe-bcab-df3314c5bcc7" class="wlWriterSmartContent">
