18.03.2011, 20:11 | #1 |
emeadaxsupport: Some reports from Reporting extensions can raise error when running on SQL 2008 R2
Источник: http://blogs.msdn.com/b/emeadaxsuppo...l-2008-r2.aspx
============== Thanks to our colleague in Japan we found problem when running some Dynamics AX reporting extensions report on SQL 2008 R2. When we open some standard SSRS reports with SQL2008R2 (ie. TSInvoicedPurchaseAmount.TS_InvoicedPurchaseAmountDetail.Report ), we receive following error. An error has occurred during report processing. (rsProcessingAborted)This is because the Item is reserved word of MDX and execution is causing the error. So to fix the problem we need to change parameter name for DataSet 'InvoiceAmountDetailedReport'. Fortunately there are already hotfixes which fixed this problems: KB2519061 TSInvoicedPurchaseAmount.TS_InvoicedPurchaseAmountDetail.Report TSInvoicedPurchaseAmount.TS_InvoicedPurchaseAmountWebpart.Report KB2520255 ProjCashFlow.ProjActualvsBudgetNetCashflow.XYChart ProjCostControl.ProjTotalBudgetCost.LineChart ProjHourUtilization.ProjUtilizationEfficiency.XYChart ProjStatements.ProjActualvsBudgetConsumption.XYChart ProjStatements.ProjActualvsBudgetCost.XYChart ProjStatements.ProjActualvsBudgetGrossMargin.XYChart ProjStatements.ProjActualvsBudgetNetWIP.XYChart ProjStatements.ProjActualvsBudgetPayroll.XYChart ProjStatements.ProjActualvsBudgetRevenue.XYChart Right now both hotfixes are not published so please contact Support Team to get both hotfixes. --author:Yuji Imaoka --editor:Czesława Langowska --date:18/March/2011 Источник: http://blogs.msdn.com/b/emeadaxsuppo...l-2008-r2.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. Последний раз редактировалось Poleax; 19.03.2011 в 13:03. |
