Старый 07.06.2011, 19:11   #1
25,531 / 847 (80) +++++++
palleagermark: Not enough rights to use table 'Common' (Common) error i Purchase Totals (PurchTotals)
Источник: http://palleagermark.blogspot.com/20...le-common.html
You can get this error from Purchase Totals if the user does not have Edit permissions to Administration / Tables. Here's is how you can fix it by changing you security setup:
http://dynamics-ax-live.blogspot.com...ity-setup.html
You can also fix the issue by modifying the form. All you need to do is to change the "AllowCheck" property of the Common data source of the PurchTotals form. Change the value from "Yes" to "No".
emeadaxsupport: Purchase Requisition Workflow in Dynamics AX 2009 fails with Stopped (error): Work item could not be created. Insufficient rights for user Blog bot DAX Blogs 0 18.11.2010 21:12
DynamicsAxSCM: Sales and purchase prices in relation to the item price setup in Microsoft Dynamics AX 2009 Blog bot DAX Blogs 0 11.02.2010 09:05
dynamicsaxtraining: Create purchase order Blog bot DAX Blogs 0 14.12.2009 14:05
dynamicsaxtraining: Purchase business process Blog bot DAX Blogs 0 07.12.2009 19:05
Not enough rights to use table 'Officials - Report lines' (OfficialsTrans_RU). почему нет прав? rusalaudinov DAX: Программирование 4 18.02.2008 10:41
Часовой пояс GMT +3, время: 13:02.
