09.07.2011, 05:58 | #1 |
Dynamics AX Sustained Engineering: NF-e Process fails with XML schema error 215 due to missing namespace
Источник: http://blogs.technet.com/b/dynamicsa...namespace.aspx
============== Problem: Resolution: Load the attached Microsoft.Dynamics.AX.NFe.dll file and register the .dll. The make the following code changes. \Classes\EFDocMsgTransport_WebServiceV4_BR\createBinding From: System.ServiceModel.Channels.TextMessageEncodingBindingElement messageEncodingBinding; To: Microsoft.Dynamics.AX.NFe.CustomTextMessageBindingElement customTextMessageBindingElement; From: messageEncodingBinding = //BP Deviation Documented new System.ServiceModel.Channels.TextMessageEncodingBindingElement( System.ServiceModel.Channels.MessageVersion::get_Soap12(), System.Text.Encoding::get_UTF8()); To: CustomTextMessageBindingElement = new Microsoft.Dynamics.AX.NFe.CustomTextMessageBindingElement("utf-8", "application/soap+xml", System.ServiceModel.Channels.MessageVersion::get_Soap12()); From: bindingElementArray.SetValue(messageEncodingBinding, 0); To: bindingElementArray.SetValue(CustomTextMessageBindingElement, 0); Источник: http://blogs.technet.com/b/dynamicsa...namespace.aspx
