13.07.2011, 16:11 | #1 |
daxdilip: Troubleshooting Dyamics AX Error No Devices found
Источник: http://daxdilip.blogspot.com/2011/07...-error-no.html
============== Issue: Recently on one of the client machine, this error message "No Devices found" started popping up while the AX Client is loaded. Solution: This is caused by an unregistered ocx file on the client. To fix this you will need to register the smmPhone.ocx located in C:\Program Files\Microsoft Dynamics AX\40\Client\Bin folder using regsvr32 Command line is: regsvr32 C:\Program Files\Microsoft Dynamics AX\40\Client\Bin\smmPhone.ocx but had to go to a cmd window, cd to the C:\Program Files\Microsoft Dynamics AX\40\Client\Bin folder and then run regsvr32 .\smmPhone.ocx Restart the box. Источник: http://daxdilip.blogspot.com/2011/07...-error-no.html
