emeadaxsupport: Microsoft Dynamics AX Enterprise Portal: How to add hyperlink field to AxGridView
Источник: http://blogs.msdn.com/b/emeadaxsuppo...xgridview.aspx
============== To add hyperlink to your AxGridView you need to use AxHyperLinkBoundField (msdn: http://msdn.microsoft.com/en-us/libr...(v=AX.50).aspx) The most important properties are following: DataSet: Data set (AOT \ Data Sets) from which data are loaded DataSetView: Table from which data are loaded DataField: Field name from which data are loaded MenuItem: Url menu item (AOT \ Web \ Web Menu Items \ Url ) where we have set up url Example (from Web Form EPSalesTableInfo) Code Snippet --author: Czesława Langowska --editor: Czesława Langowska --date: 20/July/2011 Источник: http://blogs.msdn.com/b/emeadaxsuppo...xgridview.aspx
