Здравствуйте Уважаемые!
После переезда CRM c 3.0 на 4.0 перестали удаляться сообщения эл. почты, заказы, интересы... "Плюется" ошибкой: ![]() ![]() В ЛОГах ошибка .NET : Event code: 3005 Event message: An unhandled exception has occurred. Event time: 12/8/2011 12:43:24 PM Event time (UTC): 12/8/2011 8:43:24 AM Event ID: a9925f1e16ce4639b38c5be2e062c08a Event sequence: 112621 Event occurrence: 1 Event detail code: 0 Application information: Application domain: /LM/W3SVC/1/ROOT-5-129677621065374281 Trust level: Full Application Virtual Path: / Application Path: c:\inetpub\wwwroot\ Machine name: OMEGA Process information: Process ID: 4052 Process name: w3wp.exe Account name: NT AUTHORITY\NETWORK SERVICE Exception information: Exception type: TargetInvocationException Exception message: Exception has been thrown by the target of an invocation. Request information: Request URL: http://omega/МОЯОРГАНИЗАЦИЯ/_grid/cmds/dlg_delete.aspx?iObjType=4200&iTotal=1&iIndex=0&sSubTypes=4202&sSrcQueueId=&sParentId=&sCalendarId=&iId={BD4358FA-C90A-E111-B4C9-002618CA6464} Request path: /МОЯОРГАНИЗАЦИЯ/_grid/cmds/dlg_delete.aspx User host address: 192.168.5.22 User: МОЙДОМЕН\administrator Is authenticated: True Authentication Type: Negotiate Thread account name: NT AUTHORITY\NETWORK SERVICE Thread information: Thread ID: 1 Thread account name: NT AUTHORITY\NETWORK SERVICE Is impersonating: False Stack trace: at Microsoft.Crm.Application.Utility.Util.RaiseXMLError(Exception exception) at Microsoft.Crm.Dialogs.DeleteDialogPage.ConfigureForm() at Microsoft.Crm.Application.Controls.AppUIPage.OnPreRender(EventArgs e) at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) Custom event details: For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. Посоветуйте плиз "куда дальше рыть"? |
Чайный пьяница
Поднимите SQL Timeout. Как это сделано лписано тут - http://mscrmuk.blogspot.com/2008/09/...sql-error.html
Сообщение от a33ik
![]() Поднимите SQL Timeout. Как это сделано лписано тут - http://mscrmuk.blogspot.com/2008/09/...sql-error.html
![]() Мне кажется SQL тут непричем... Ругаецца на .NET Я в свойствах сайта, в свойствах АSP.NET изменил значение Request timedout - с 300 на 600 - тоже не помогает... ![]() |
Чайный пьяница
Включите трейс, перезапустите иис, воспроизведите ошибку, покажите лог, который появился - http://support.microsoft.com/kb/907490
