04.01.2012, 06:12 | #1 |
dynamicscpm: Creating Consolidated Financial Statements using Management Reporter – Consolidating data across one or multiple Dynamics ERPs with the same chart of accounts and same fiscal periods (Part 1 of 7)
Источник: http://blogs.msdn.com/b/dynamicscpm/...rt-1-of-7.aspx
============== Many organizations need to prepare financial statements that report on multiple companies in a consolidated format. Management Reporter can help a company consolidate their data across one Microsoft Dynamics ERP, multiple Microsoft Dynamics ERPs, or across ERPs. Consolidations can also occur at different levels, based on a company’s needs. This series of blogs will help you determine which consolidation options in Management Reporter are right for your business and provide you with information on how to create consolidated financial statements on consolidating data in Management Reporter.
TIP: Verify all dimensions are named the same. For example, if Company CEU has a dimension named Department, verify it is also named Department in CEE, not Dept or Segment 1. The high level steps to consolidating using a reporting tree are:
Next create a row definition, ensuring that all appropriate accounts in all companies are included in the rows. Then create a column definition that includes the columns required for the report you are creating. Finally, create a reporting tree that includes a reporting node for each of the companies that you are using on consolidated reports. The following shows an example of using a Management Reporter Reporting Tree Definition to identify each company you will be consolidating. When you use this reporting tree with a report definition, you can view each company individually with the consolidated amounts displayed at the summary level. Viewing companies side by side Many customers prefer seeing each company side by side in the report and then a consolidated total column. This is very easy to do once you have the reporting tree created.
