Старый 09.02.2012, 23:15   #1
emeadaxsupport: AX for Retail: Receipt footer is not displaying Tax information
Источник: http://blogs.msdn.com/b/axsupport/ar...formation.aspx
Issue description:
The customer adds the TAX information in the receipt footer, but the information is not printed on the receipt.
The issue has been identified to be a problem with the Seed data that is inserted when running the HQ/Setup/Parameter/Initialize
In the POSISFormlayout we have a FooterXML field for each report, which consist of a long string like.
Example
3C6865616465723E0D0A20203C6C696E65206E723D223030222049443D225465787422204E756D6265726F66436F6C756D6E733D223536223E0D0A202020203C63686172706F7320
The POSISFormlayout data is being inserted through the DRMSeedDataGenerator that calls AOT/RESSOURCES/RBO_Footer_1_txt
The workaround is export the R1 demo data from POSISFormlayout table and field FooterXML
Then export the resource from your R2/R2 Refresh and replace the string from the R1 data and import it back.
After that you can run the Retail HQ/Setup/parameters/initialize
The result is that the footer lines with the tax is printed
Corrected file added that can be added to the AOT/Ressources
Author: Kim Truelsen
Blog date: 9-2-2012
Dynamics AX Sustained Engineering: Sales tax information is not recaculated if document date is changed in a journal when sales tax is calculated using document date Blog bot DAX Blogs 0 22.06.2011 08:13
emeadaxsupport: The Dynamics AX 2009 AOS does not start with "The license information can not be decoded" error Blog bot DAX Blogs 0 22.09.2010 23:05
Часовой пояс GMT +3, время: 17:45.
