fed: Net requirements update in MRP Module and Working Set of MRP
Источник: http://fedotenko.info/?p=247
============== Most of Dynamics AX specialists (especially from support) heard about inventSumLogTTS table. Everyone knows that this table somehow is related to MRP; Everyone knows that if you do not run MRP, your inventSumLogTTS table grows bigger and bigger and eventually you need to clean it somehow. But since detailed documentation on static/dynamic plan update algorithms is absent, not many people understand how Axapta actually use this table for plan updates; what are advantages and caveats of dynamic vs static plan use;how order explosion differs from regeneration planning and so on… I wrote this text mostly from my experience with Dynamics AX 2009. In the new version (DAX2012) approach remained the same from functional point of view, only technical details changed, so this information can be useful also for people using DAX2012. A bit of history As I wrote in my blog before, inventSumLogTTS table began its life (somewhere in late releases Axapta 2.5) only as a tool to track a list of changes which was applied to inventSum table in independent DB transaction. Should the main transaction be rolled back, the system was to iterate over related records in inventSumLogTTS and programmatically rollback changes to inventSum. Starting from Axapta 3.0, inventSumLogTTS table started to be used to support dynamic update to MRP plan. In version Dynamics AX 4.0, the whole Inventory MultiTransaction System was dropped from Axapta and replaced with new approach. Nevertheless inventSumLogTTS table still exists in the system, but nowadays it is used only to support dynamic MRP plan update. Today, name of the table is misleading, because now it is not used to log InventSum updates. As of versions 4-2012 it is used only to keep track of inventTrans changes, which have not been applied to dynamic plan yet. How data gets into inventSumLogTTS The mechanism which now (in versions 4.0/2009/2012) is creating new records in inventSumLogTTS is the very same mechanism which is used to update inventSum. (I described this mechanism in details in the article I mentioned). When inventTrans is inserted/updated/deleted the system calls inventUpdateOnHand.addInventSumLogTTS() method to register deletion or insertion of inventTrans. (and update goes as a delete and insert). InventSumLogTTS records are kept in cache till the end of transaction and are actually written to database at the same time when the system updates inventSum records, related to inventory updated in transaction. To link two records of inventSumLogTTS related to the same update of an inventory transaction, the system uses the sequenceNumber field of the inventSumLogTTS table. The system registers changes of inventTrans record, till it become physically/financially updated (Deducted/Sold or Received/Purchased statuses). Only the very first change of the transaction to physical/financial status is registered to inventSumLogTTS. Later this change is to be applied to Net Requirement of On-Hand type by dynamic plan update mechanism. Subsequent changes to the same inventory transaction are not recorded, since they are not anymore relevant for MRP, since now the transaction is a part of OnHand Stock which is represented in Net Requirements as a one on-hand net requirement per item and coverage dimensions. Working Set of MRP and a bit of terminology To simplify further discussion I want to introduce a new term – Working Set. I will use this term to describe a list of net requirements which are participating in current MRP session. In different stages of MRP session, content of that list is different. After update phase, it contains issue net requirements to be covered, during coverage phas it contain mixture of covered issue net requirements, covering receipt net requirements and uncovered issue net requirements to be covered. After coverage phase, working set contains only covered/covering net requirements. But the point is: Working set of MRP session is the most fundamental thing for understanding of MRP process and it always defined by adding to it uncovered issue net requirements. Everything else is implementation details. Generally, there are two ways to start MRP: One is to start MRP from Master Planning->Periodic->Master planning; Another – to click Master Planning->Periodic->Master planning in Requirement Profile form. The menu items point to different classes. From implementation point of view, both classes use different algorithms. First class is optimized for multi-threaded scheduling of large number of net requirements. Second is optimized for scheduling for only 1 item, but it has good caching mechanisms, so it might work much faster sometimes. I will use term Full MRP for MRP from Periodic menu and term Item MRP for MRP from Requirement Profile form. From functional point of view, there is a serious difference between these two kinds of MRP. Item MRP runs on the level of specific net requirements; Full MRP works on the level of item-coverage dimension combination. When net requirement is added to Working Set of Full MRP, it implicitly adds whole net requirements with a given item and coverage dimension combination into Working Set. Technically speaking, Item MRP is implemented by combination of classes ReqCalcScheduleItem (Responsible for the planning process itself) and ReqTransCache_Daily(Responsible for Working Set support). ReqTransCache_daily class holds a set of itemIds in a Working Set, a set of coverage dimension combinations for every item in a Working Set and a map with Net Requirements of Working Set itself. Full MRP is implemented by combination of classes ReqCalcScheduleItemTable (responsible for planning process) and ReqTransCache_Periodic (Responsible for Working Set support).ReqTransCache_Periodic class holds only a set of items and set of coverage dimensions for items in a Working Set. (Technically these sets are stored as ReqProcessItemListLine and ReqProcessItemDim list tables). As we will see later, working set is created on Update phase of MRP session (I will use term Initial Working Set for it), but can grow as a result of Coverage phase of MRP Session (I will use term Extended Working Set for working set after extension by coverage planning). I will also occasionally use term Items in working set, to refer to the list of items which have net requirements in the given Working Set; Sometimes, I will also use term Session Item Set to designate the set of items defined before MRP start. In case of Item MRP, this item is defined by current content of Requirements Profile form; In case of Full MRP, the items are defined by query parameters in dialog box which is popping up in beginning of MRP process Simplest case: Regeneration of static plan Before we proceed our discussion any further, I want to discuss a bit the simplest case of MRP: Regeneration of static plan. If we are running MRP in regeneration mode, here is what happens:
More complex case: Regeneration of dynamic plan Regeneration of dynamic plan generally work the same way as regeneration of static plan only with few extra steps added:
I want specially mention, that the the net requirements updated on Dynamic Update Stage, are not automatically included into the Working Set. Dynamic Update Stage is not very fine-grained; It runs on level of item;It might be that Dynamic Update has updated net requirements with configuration, sizes or colors that have nothing in common with the current Session Item Set. Thus, inclusion of all updated net requirement for an item into a Working Set, would cause unnecessary increase in a Working Set size and increase complexity of planning. Interesting side effect of inventSumLogTTS application is that MRP session can adapt to latest changes to inventTrans made by users during planning session. Say, if we have item with BOM Level 4 in our Session Item Set, it might happen that between initial net requirements creation and coverage planning for BOM Level 4, a user will make a set of changes to inventTrans for the item. Since coverage planning for item starts from propagation of recent inventTrans changes to net requirements, results of MRP will be consistent with inventTrans state in the beginning of coverage process for given item. In case of regeneration of static plan, reqTrans state is consistent with the state of inventTrans during initial net requirement update phase; All subsequent changes to inventTrans are not reflected in net requirements. Net change update of dynamic plan In Net Change/Net Change minimized mode,update phase of MRP is executed in entirely different way. It is simply a sequence of Dynamic Updates for items in a Session Item Set. The system iterates over the Session Item Set and for every item it calls usual net requirement update mechanism (reqTransUpdate class), so that relevant net requirements will be updated with recent information from inventSumLogTTS. As a result of this update, some of net requirements are dropped, some are created, for some requirements quantity is changed. Next, during coverage phase, coverage process uncovered issue net requirements in Working Set. Again, before running coverage process for an item, the system run usual net requirements update mechanism as usual, so even items not in Session Item Set have their net requirements updated after coverage phase. Regarding requirement update phase, there are two difference between Net Change and Net Change minimized modes:
Say, you have a 80 pieces of an item in stock and a sales order for exactly 50 pieces item with delivery date in distant future. (Say – in 6 month). Regular nightly planning in regeneration mode, created coverage record between these two net requirements. SalesLine is fully covered with invent on-hand, while invent on-hand net requirement has 30 free pieces left. This 30 pieces can be used to cover something else. Suppose that on next morning a customer came and placed an urgent order for 70 pieces of the item with delivery date of tomorrow. Common sense tells us that we can use our current on-hand to cover this new urgent sales order and for remaining uncovered 40 pieces of non-urgent sales order we can create appropriate planned order with execution date in distant future (in a few days before non-urgent order’s delivery date). Instead of this, Net Change planning will use remaining 30 pieced of on-hand to cover urgent sales order and will create extra urgent planned order for remaining 40 pieces with execution date of today. It happens, because net change/net change minimized never touches net requirements which had not had related inventTrans changed. During update phase, the system creates new net requirement for 70 pieces for tomorrow. It cannot ‘release’ on-hand net requirement for more urgent order, because it cannot touch it! During coverage phase it creates coverage record for 30 pieces between existing (not touched by Dynamic Update) on-hand net requirement and new sales net requirement. For remaining 40 pieces, the system creates new planned order. The only way to solve this issue is to run regeneration mode scheduling for an item and all nested sub-components. If we run regen mode scheduling only for item in new urgent sales order, we won’t have the phenomena for the net requirements of item itself. But if this item is a BOM with sub-components, it means for sub-component items, the same problem can arise on next BOM Levels. I am a bit surprised, that standard Dynamics AX does not have some special ‘Explosion regen MRP’ which would take item or item mask as an input and then build INITIAL working set from all sub-components of item entered. I made this functionality for a couple of projects. It works much faster then full regeneration scheduling and it works somewhat slower then explosion. (Which is working on different set of principles and is just a special case of Net Change Minimized planning). This MRP extension also happens to fix the issue of incorrect planned orders for items with Period coverage code, which I mentioned in the section before previous. Explosion Explosion is a special kind of Net Change dynamic plan update. By definition, explosion only can be run for current dynamic plan. The most fundamental difference between explosion and regular MRP is that explosion includes into Initial Working Set ONLY net requirements belonging to the specific order or line of the order. It also means that it is the most fine-grained MRP kind. Since it is the most fine-grained kind of planning, it uses the same approach for working set update as Item MRP do. Working Set for explosion also stores working set as a set of particular net requirements, not as a set of item and coverage dimensions combinations. During requirement update stage, the system will simply run run Dynamic Update for the item of the net requirement being exploded and then create Initial Working Set from this net requirement and derived demand net requirements (sub-components for the planned production order or production order; derived net requirements on refill warehouse in case of planned transfer order and so on). The subsequent stages goes more or less in the same way as for Net Change Minimized dynamic plan update. There are three kinds of explosion:
Two plans scheme Standard MRP tutorials describes the idea of two plans schema in details. Shortly speaking, we have two plans – static and dynamic. Static plan is fully regenerated every night (or maybe every second night, every Saturday and so on…) and copied into dynamic plan. During daytime (between two static plan regenerations), production, purchase and logistics departments works with static plan. (Since it is stable and kept in ’up-to-the-rules’ state), while sales managers works with dynamic plan, running explosions for newly created sales orders. In this case, sales managers have a tool to make reasonable estimation for a sales order delivery time, while all other departments work with stable plan without irregularities caused by last moment change. In this case, if Full MRP is run and Session Item Set contains all items, update phase for static plan is also dropping all info from inventSumLogTTS table. The logic behind it is clear: Since we are running full regen and we are going to copy it results to dynamic plan anyway, there is no much point in keeping our old update log. In the beginning, we will drop inventSumLogTTS, create static plan from the scratch, then after MRP finish, we will copy static plan to dynamic. InventSumLogTTS at this moment will contain the list of updates to inventTrans made after initial plan regeneration. If user try to run explosion or dynamic plan update in Net Change/Net Change Minimized mode, the system will handle it in the same way as usual dynamic update of dynamic plan. Change of current dynamic plan If you try to change current dynamic plan settings in master planning parameters, you can encounter strange behavior. An attempt to change, the system will pop-up a dialog box with the message “Update and move transactions to new dynamic master plan?”. If you agree, on attempt to save changes, the system will hang for a while. After that you will be surprised a lot: Your new dynamic plan will contain exactly the same information as old dynamic plan. The system was hanging during parameters update just because it was copying old dynamic plan content into new dynamic plan… On a first sight it looks totally weird and counter-intuitive. We are deliberately changing dynamic plan and yet, as a results, we have the same plan under a different name. But if we think more about it, it is not so weird at all. Say, we just changed current dynamic plan without copying. What should the next explosion do ? We have a lot of recorded changes in inventSumLogTTS; Which of them should be applied to the new dynamic plan and which – should not ? There is no way to know. We have only one dynamic plan which is synchronized with inventTrans/InventSumLogTTS state. So, if we are changing current dynamic plan settings, there is only one relatively fast way to bring it to synchronous state – to copy old dynamic plan (which is kept in sync by definition) to new one. An alternative approach would be to run Full MRP in regeneration mode, but it would require much more time and DB/AOS server capacity. That’s why designers of MRP module in Dynamics AX decided to always copy dynamic plan on change of current dynamic plan setting. Dynamic Update process Dynamic update algorithm is pretty straightforward. The system runs over the inventSumLogTTS records for the specified item sorted by sequence id and apply every change to underlying net requirement record (reqTrans). There are few points to be made though:
#2 |
Ищущий знания...
Жалко что не на русском
"Страх перед возможностью ошибки не должен отвращать нас от поисков истины." (с) С Уважением, Елизаров Артем |
За это сообщение автора поблагодарили: EVGL (0). |
#3 |
Axapta
Вообще странно, что у разработчиков есть проблемы с чтением технических текстов на английском (как вообще работать, почти вся полезная информация же на нем?), но поскольку статья полезная, можно для будущих поколений попробовать совместно перевети ее на русский. Все я сейчас не осилю, но могу начать. Вот первые 10%. Переводилось бегло, местами коряво, но всяко лучше автоматического перевода. Кто-нибудь продолжит? Еще девять добровольцев, каждый по одной вордовской страничке, и все будет переведено.
fed: Обновление чистых потребностей в модуле MRP и Working Set* в MRP
*термин "Working Set" я не перевожу, данный термин ввел fed непосредственно в статья, и в ней же объясняется его значение. О таблице inventSumLogTTS слышало большинство специалистов Dynamics AX (особенно работающих на поддержке). И все знают, что данная таблица как-то связана с MRP и что если не запускать MRP, то таблица inventSumLogTTS будет становиться все больше и больше, так что, в конце концов, ее каким-либо образом придется чистить. Но из-за того, что для алгоритмов обновления статических и динамических планов подробной документации нет, очень немногие специалисты действительно понимают то, как на самом деле используется данная таблица при обновлении планов, каковы преимущества и какие есть нюансы использования динамических и статических планов, чем развертывание заказов отличается от планирования с пересозданием и пр. Я написал данный текст в основном по своей работе с Dynamics AX 2009, но в новой версии (DAX2012) подход остался с функциональной точки зрения таким же, изменились только технические детали, поэтому текст может быть полезен и для специалистов, использующих DAX2012. Исторический экскурс Как я уже писал в своем блоге, таблица inventSumLogTTS появилась где-то в последних релизах Axapta 2.5 исключительно для отслеживания изменений в таблице inventSum в отдельной транзакции на уровне БД. И в случае если основная транзакция откатывалась, система должна была пробежаться по соответствующим записям в таблице inventSumLogTTS и программно откатить изменения в inventSum. Начиная с версии Axapta 3.0 таблица inventSumLogTTS стала использоваться и для обновления динамических MRP планов. Однако в версии Dynamics AX 4.0 система множественных складских транзакций из Аксапты была удалена и вместо нее стал и спользоваться иной подход. Несмотря на это, таблица inventSumLogTTS в системе все еще существует, но в настоящее время используется только при обновлении динамических планов. И поэтому ее название может вводить в заблуждение, ведь она больше не используется для журналирования записей InventSum. Каким образом в таблицу inventSumLogTTS попадают данные Механизм создания новых записей в inventSumLogTTS в последних версиях Аксапты (4.0/2009/2012) похож на механизм обновления InventSum, который я уже подробно описывал в статье, упомянутой в предыдущем разделе. При вставке/обновлении/удалении записей в таблице inventSum система вызывает метод inventUpdateOnHand.addInventSumLogTTS(), который и регистрирует вставку или удаление записи в InventSum (обновление отражается как удаление и затем вставка). Записи в таблице InventSumLogTTS сохраняются в кэше до конца транзакции и вставляются в базу данных только тогда, когда система непосредственно обновляет записи в таблице InventSum, связанных со складским обновлением в транзакции. Для связи двух относящихся к одному и тому же обновлению в складской транзакции записей таблицы inventSumLogTTS система использует поле sequenceNumber. Система фиксирует изменений в записях InventTrans только до тех пор, пока они не будут обновлены физически или финансово (статусы Отпущено/Продано или Получено/Закуплено). При этом в таблице inventSumLogTTS фиксируется только самое первое изменение в транзакции, приводящее к физическому или финансовому статусу. Последующие изменения в той же складской транзакции уже не записываются, поскольку они больше для MRP не нужны, так как теперь эта транзакция является частью запасов в наличии, которые представлены в чистых потребностях как одна чистая потребность на каждые товар и аналитику покрытия. ... |
За это сообщение автора поблагодарили: mazzy (10), sukhanchik (10), Logger (10), S.Kuskov (10), Dark Light (1). |
#4 |
Ищущий знания...
Сообщение от oip
![]() Вообще странно, что у разработчиков есть проблемы с чтением технических текстов на английском (как вообще работать, почти вся полезная информация же на нем?), но поскольку статья полезная, можно для будущих поколений попробовать совместно перевети ее на русский. Все я сейчас не осилю, но могу начать. Вот первые 10%. Переводилось бегло, местами коряво, но всяко лучше автоматического перевода. Кто-нибудь продолжит? Еще девять добровольцев, каждый по одной вордовской страничке, и все будет переведено.
![]() ![]() З.Ы. у кого есть желание, можете забросать меня грязными тряпками ![]() ![]()
За это сообщение автора поблагодарили: mazzy (2). |
#5 |
Axapta
Мне все-равно на каком языке (русском или английском) читать технические тексты.
![]() Последний раз редактировалось oip; 27.04.2012 в 13:44. Причина: Не, на китайском не читаю. Дополнил. :) |
За это сообщение автора поблагодарили: Lucky13 (0). |
#6 |
#7 |
Недавно был ещё пост про inventSumLogTTS и Динамический план dynamicscare: Running a Dynamic Plan in Dynamics AX, но из него я мало что понял.
В этом же труде fed'а все разжёвано для самых ленивых. Огромное спасибо тебе, Денис! |
#8 |
#9 |
Пожалуй что ключевой кусок сам переведу:
Рабочий набор MRP и немного терминологии
Для упрощения дальнейшей дискуссии, я хочу ввести новый термин – Рабочее множество. Я буду использовать этот термин для того чтобы сослаться на набор чистых потребностей участвующих тем или иным образом в текущей сесии сводного планирования. На различных стадиях сводного планирование, содержимое этого набора изменяется. После стадии обновления, он состоит из чистых потребностей, подлежащих покрытию; Во время выполнения стадии покрытия он содержит смесь покрытых чистых потребностей, использованых покрывающих чистых потребностей и непокрытых чистых потребностей подлежащих покрытию в дальнейшем.После завершения стадии покрытия, этот набор состоит из полностью покрытых отрицательных чистых потребностей и использованых покрывающих положительных чистых потребностей. Основной посыл введения данного термина следующий: Рабочий набор сводного планирования является наиболее фундаментальным понятием необходимым для понимания работы сводного. Он всегда создается путем добавления непокрытых отрицательных чистых потребностей. Все остальное - подробности реализации. В целом - существует два способа запуска сводного планирования: Один - через Master Planning->Periodic->Master planning;Второй - через Master Planning->Periodic->Master planning в форме Чистых Потребностей. Данные пункты меню ссылаются на разные классы. С точки зрения реализации, это классы используют различные алгоритмы. Первый класс спроектирова для многопоточной обработки большого количества чистых потребностей. Второй - соптимизирован для сводного планирования всего одной номенклатуры, но этот класс имеет хорошие механизмы кэширования данных и может временами работать заметно быстрее. Я буду использовать термин Полное MRP для того планирования которое запускается из меню Periodic и термин Номенклатурное MRP для того планирования, которое запускается из формы Чистых потребностей. С функциональной точки зрения, данные два типа сводного планирования достаточно сильно отличаются друг от друга: Номенклатурное MRP работает на уровне определенного набора чистых потребностей. Полное MRP работает на уровне комбинации номенклатуры и аналитики покрытия. В тот момент когда чистая потребность добавляется в Рабочий Набор Полного MRP , это неявным образом добавляет не только данную чистую потребность, но и вообще все чистые потребности с данной комбинацией номенклатуры и аналитики покрытия. С технической точки зрения, Номенклатурное MRP реализовано как комбинация классов ReqCalcScheduleItem (ответственного за собственно процесс планирования) и класса ReqTransCache_Daily(ответственного за поддержку Рабочего Набора) Класс ReqTransCache_Daily хранит список номенклатур в Рабочем Наборе, список комбинаций аналитик покрытия для каждой номенклатуры в Рабочем Наборе и собственно map с чистыми потребностями. Полное MRP реализовано как комбинация классов ReqCalcCacheScheduleItemTable (ответственного за собственно планирование) и ReqTransCache_Periodic(ответственного за поддержку Рабочего Набора). Класс ReqTransCache_Periodic хранит только набор номенклатур и комбинаций аналитик покрытия для каждой номенклатуры в Рабочем Наборе (Это списки хранятся в таблицах ReqProcessItemListLine и ReqProcessItemDim). Как мы, в дальнейшем, увидим, Рабочий Набор создается процессом сводного планирования на фазе Обновления (Я буду называть это Исходный Рабочий Набор), но может быть дополнен на стадии Покрытия (Я буду использовать термин Расширеный Рабочий Набор для Рабочего Набора с дополнительными чистыми потребностями добавленными на стадии Покрытия). Время от времени, я буду использовать термин Номенклатуры Рабочего Набора для того чтобы сослаться на все номенклатуры имеющие чистые потребности в данном Рабочем Наборе ; Иногда я также буду использовать термин Номенклатуры Сессии чтобы сослаться на набор номенклатур, заданных пользователем при запуске сессии сводного планирования. В случае Номенклаурного MRP этот список состоит из единственной номенклатуры взятой из текщей строки формы чистых потребностей;В случае Полного MRP эти номенклатуры определяются параметрами запроса по InventTable, которые пользователь задал в диалоговом окне при запуске сессии сводного. |
За это сообщение автора поблагодарили: mazzy (20), George Nordic (15), sukhanchik (10), Logger (10), lev (16), Raven Melancholic (10), oip (5), gl00mie (10), Atar (2), driller (2), S.Kuskov (27). |
#10 |
Ищущий знания...
#11 |
Простейший случай: Регенерация статического плана
Прежде чем мы продолжим обсуждение, я хочу рассмотреть простеший случай сводного планирования: Регенерацию статического плана. Вот как происходит процесс планирования в данном случае.
#12 |
Более сложный пример: Регенерация динамического плана
Регенерация динамического плана работает примерно также как и регенерация статического, однако несколько шагов все-таки добавлено:
Я хочу специально заметить, что те чистые потребгости, которые оказались обновлены на стадии Динамического обновления не включаются автоматически в Рабочее множество. Динамическое обновление не особо изберательно; Оно выполняется на уровне конкретной номенклатуры. Может так случится, что Динамическое обновление обновило чистые потребности с конфигурациями, размерами или цветами, которые ничего не имеют общего с текущей Номенклатурой сессии. Таким образом, включение всех случайно обновленных чистых потребностей по номенклатуре в Рабочий Набор вызвало бы ненужное увеличение размера Рабочего набора и увеличило бы сложность планирования. Интересный побочный эффект от применения данных в inventSumLogTTS состоит в том, что сессия сводного планирования может адаптироваться к последним изменениям складских проводок, сделанных пользователями во время работы планирования. Предположим, что у нас в Номенклатуре сессии присутствует некая номенклатура с уровнем вложенности 4.Может так случится, что между начальной регенерацией чистых потребностей, какой-то пользователь выполнит складские операции по данной номенклатуре (например порезервирует какие-то заказы). Поскольку рассчет покрытия по номенклатуре начинается с применения к чистым потребностям записанного в inventSumLogTTS протокола по данной номенклатуре, результаты расчета будут соответствовать состоянию inventTrans на момент начала рассчета покрытия по данной номенклатуре.В то же время, в случае регенерации статического плана, состояние чистых потребностей соответствует состоянию inventTrans в момент начальной регенерации чистых потребностей. Все последующие изменения складских проводок не отражаются в чистых потребностях. |
#13 |
Обновление динамического плана в режиме Накопленные изменения(Net Change) В режиме Накопленные изменения/Минимальные изменения (кстати отмечу неудачность русского перевода терминов Net Change/Net Change Minimized), фаза Обновления плана выполняется совершенно другим образом. Попросту говоря, это последовательность Динамических обновлений для всей номенклатуры из Набора сессии. Система пробегается по всем номенклатурам из Набора сессии и для каждой номенклатуры вызывается обычный класс обновления чистых потребностей (reqTransUpdate), который собственно и переносит в чистые потребности накопленную информацию об изменениях, хранящуюся в таблице inventSumLogTTS. В результате этого обновления, часть чистых потребностей удаляется, часть - создается, для у части чистых потребностей изменяется количество или другие релевантные поля. Затем, во время фазы рассчета покрытия, система пробегается по всем непокрытым отрицательным чистым потребностям в Рабочем множестве. Как и в режиме регенерации динамического плана, система, перед рассчетом покрытия по каждой номенклатуре, запускает стандартную процедуру Динамического обновления. Таким образом, даже для номенклатур не входящих в Набор сессии данные чистых потребностей актуализуются в соответствии с текущим состоянием складских проводок. С точки зрения фазы обновления чистых потребностей, хочу отметить два отличия между режимами Накопленных изменений и Минимальных изменений:
Допустим у нас на складе есть 80 штук некой номенклатуры, а также имеется заказ на продажу 50 штук этой же номенклатуры с датой доставки из далекого будущего (Допустим - через 6 месяцев). Регулярное ночное сводное планирование, создало запись о покрытии между двумя соответствующими чистыми потребностями. Потребность заказа на продажу полностью покрыта запасами в наличии, в то же время у чистой потребности запасов в наличии осталось неиспользованных 30 штук. Эти 30 штук могут быть использованы для того чтобы в будущем покрыть что-то еще.Предположим что на следующее утро пришел клиент и попросил срочно отгрузить ему 70 штук нашей номенклатуры. Здравый смысл подсказывает нам, что мы должны покрыть этот заказ номенклатурой в наличии, а для оставшихся непокрытыми 40 штук несрочного заказа создать плановый заказ эдак за пару дней до планирующейся даты отгрузки этого несрочного заказа. Вместо этого, планирование в режиме Накопленных изменений использует для покрытия срочного заказа только те 30 штук из запаса в наличии, которые остались свободными после ночного перепланирования 30 штук из номенклатуры в наличии, а для недостающих 40 штук оно создаст срочный плановый заказ с сегодняшней датой исполнения. Это происходит, поскольку планирование в режиме Накопленых обновлений/Минимальных обновлений никогда не трогает те чистые потребности, у которых не было изменены соответствующие складские проводки. На фазе обновления, система создает новую чистую потребность на 70 штук с завтрашней датой. Система не может 'Освободить' чистую потребность 'В наличии', для срочного заказа, поскольку она не может модифицировать эту чистую потребность ! Во время фазы покрытия, система создает запись покрытия на 30 штук между новым заказом и запасами в наличии (чистая потребность которых не была модифицирована Динамическим обновлением), а затем, для покрытия оставшихся 40 штук, система порождает новый спланированный заказ. Единственный способ исправить эту ситуации - это запуск сводного в режиме регенерации для данной номенклатуры и для всех субкомпонентов данной номенклатуры (или вообще для всех номенклатур в системе).Если мы запустим регенерацию только для данной номенклатуры, то с чистыми потребностями по самой номенклатуре все будет хорошо. Однако же если данная номенклатура - это спецификация с субкомпонентами, это означает что для субкомпонентов чистые потребности не будут удалены и перегенерированы с ноля и точно такая же проблема может возникнуть на следующих уровнях вложености. Я слегка удивлен что стандартная версия Dynamics AX не поддерживает некого специального режима "Регенерации развертывания", который бы получал на входе номенклатуру или маску номенклатуры, а затем бы строил НАЧАЛЬНЫЙ рабочий набор из указанных номенклатур и всех их субкомпонентов.Я реализовал подобную функциональность для пары проектов; Она работает заметно быстрее чем полная регенерация плана (для всех номенклатур) и заметно медленнее чем стандартное развертывание.(Которое работает на другом наборе принципов и является частным случаем режима Минимальных обновлений).К слову сказать, это расширение стандарта MRP также исправляет проблему некорректного планирования для режима покрытия Период, о котором я писал в позапрошлом разделе. |
#14 |
Развертывание (Explosion) Развертывание - это просто такой специальный вариант режима обновления Минимальные изменения.По определению, развертывание может запускаться только для текущего динамического плана.Наиболее фундаментальное отличие между развертыванием и обычным сводным планирование состоит в том, что развертывание включает в Начальный Рабочий Набор ТОЛЬКО чистые потребности относящиеся к специфическому документу или даже строке документа. Поскольку развертывание является наиболее 'точечным' вариантом сводного планирования, оно использует тот же подход к обновлению Рабочего набора что и Номенклатурное MRP. Рабочий набор развертывания также хранится как набор конкретных чистых потребностей, а не как набор комбинаций номенклатуры и аналитик покрытия.На стадии обновления чистых потребностей, система просто запускает Динамическое обновление для номенклатуры той чистой потребности, для которой выполняется развертывание, а затем создает Начальный рабочий набор для из данной чистой потребности и связанных с ней зависимых чистых потребностей (компонентов в случае спланированного производственного заказа или производственного заказа, зависимые потребности в номенклатуре на складе пополнения в случае спланированого заказа на перенос и т.д.). Последующие стадии выполняются более или менее тем же способом, что и в режиме Минимальных Изменений. Существует три разных варианта Развертывания:
#15 |
Схема с двумя планами Стандартные учебники по сводному планированию детально описывают идею использования схемы с двумя планами.Коротко говоря, у нас есть два плана - статический и динамический. Статический план полностью пересчитывается в режиме регенерации каждую ночь (каждую вторую ночь, каждую субботу и тп), а затем копируется в динамический план. Днем (строго говоря - в любое время между двумя перегенерациями статического плана), департаменты закупок, логистики и производства работают со статическим планом (поскольку он стабилен и лучше соответствует,эээ, набору правил планирования); В то же время менеджеры по продажам работают с динамическим планом и могут запускать развертывание для вновь созданных заказов на закупку. При данном подходе, менеджеры по продажам имеют инструмент, позволяющий им прикинуть реалистичную дату поставки по размещенному заказу, а все остальные подразделения работают со стабильной версией плана, которая не имеет проблем вызванных оперативными обновлениями. В этом случае, если исполняется Полное MRP и Набор сесии содержит всю номенклатуру и включен режим автоматического копирования статического плана в динамический, во время фазы обновления, все содержимое таблицы InventSumLogTTS удаляется. Причина этого ясня: Поскольку мы перегенерируем весь план и собираемся результат планирования скопировать в динамический план, нет никакого смысла сохранять старый журнал обновлений.В начале мы вычистим всю информацию из inventSumLogTTS, создадим статический план с ноля, затем, когда MRP завершится, мы скопируем статический план в динамический. В этот момент, в таблицу inventSumLogTTS будет хранится протокол изменений складских проводок, выполненых после завершения начальной фазы обновления. Если пользователь попробует запустить развертывание или перепланирование в режиме Накопленных Изменений или Минимальных Изменений, система отработает в обычном режиме динамического обновления динамического плана... Смена текущего динамического плана Если вы попытаетесь сменить текущий динамический план, вы столкнетесь со странным поведением системы. При попытке замены, система выкинет диалоговое окно с загадочным сообщением: "Обновить и переместить проводки в новый динамический генеральный план?" (Кстати хочу отметить традиционно низкое качество перевода. Не очень понятное английское сообщение было заменено на абсолютно непонятное русское.) Если вы согласитесь, в момент записи изменений, система надолго зависнет. А затем, вас ждет большой сюрприз: Ваш новый текущий динамический план будет содержать в точности те же самые данные что и ваш бывший динамический план.Система висела как раз потому что она копировала содержимое из старого динамического планеа в новый. На первый взгляд, это выглядит ненормальным и неожиданным. Мы осознано решили сменить динамический план, но, тем не менее, в качестве результата мы получили тот же самый старый план, просто под другим именем.Но если мы разберемся в проблеме глубже, всё это не так уж и ненормально. Допустим мы поменяли текущий диинамический план без копирования. Что делать следующему развертыванию ? У нас в InventSumLogTTS хранится информация о куче изменений; Какие из них должны быть применены к новому динамическому плану, а какие -нет ? В системе для этого нету необходимой информации. Есть только один динамический план, который засинхронизирован с состоянием данных в таблицах inventTrans/inventSumLogTTS. И когда мы меняем текущий динамический план, существует только один относительно быстрый способ засинхронизировать новый план с этими данными - это скопировать старый план в новый. Альтерантивой был бы запуск Полного MRP в режиме регенерации, но это потребовало бы значительно больше времени и ресурсов от серверов БД и AOS. Именно по этому, разработчики модуля сводного планирования в Аксапте предпочли копировать старый план в новый при любой попытке изменения текущего динамического плана. Процесс динамического обновления Процесс динамического обновления достаточно прямолинеен.Система пробегает по записям таблицы inventSumLogTTS, для данной номенклатуры, отсортированным по номеру обновления (sequence number) и применяет каждое запротоколированное изменение к соответствующей записи чистых потребностей. Тем не менее, я хочу отметить несколько фактов:
За это сообщение автора поблагодарили: AlGol (2), Maximin (6), db (10), sukhanchik (20), lev (16), serg.epshtein (1). |
Теги |
сводное планирование |
Тема | Ответов | |||
fed: Two stories about inventory closing and SQL Locks | 3 |
