workflowax: Organisation-wide Workflow Email Templates
Источник: http://workflowax.wordpress.com/2012...ail-templates/
============== If you make use of organisation wide workflow configurations in AX2012 you may have come across an issue where users are not notified of their new work-items via Email. To set this up you will need to: 1. Navigate to your email templates under the Setup menu of “Organisation Administration”. 2. Select the “Show system email templates” 3. Create a new Email template. ![]() 4. Navigate to “System Administration” -> “Setup” -> “Workflow Parameters” and select your newly created email template. (For company specific configuration AX looks at the template selected under “Organisation Administration” -> Setup -> Workflow Parameters) Your users should now be notified of “Organisation-wide” workflow workitems. ![]() Источник: http://workflowax.wordpress.com/2012...ail-templates/
