Старый 13.09.2012, 21:11   #1
25,643 / 848 (80) +++++++
ax-erp: ‘Not Like’ in Dynamics AX
Источник: http://microsoft-dynamics-ax-erp.blo...namics-ax.html
In X++, we can use Like ‘*someIdentifier’ to implement the Like keyword.
e.g.
select firstonly purchTable
where purchTable.purchId like 00007*‘;
However if you want to use ‘Not Like’ in X++ SQL statement, you have three options:
The first option, using ‘!’ as ‘not’,
e.g.
where !(purchTable.purchId like ‘00007*‘);
The second option, using notExists join
e.g.
PurchTable purchTable, refPurchTable;
notExists join refPurchTable
where purchTable.purchId ==00007*‘;
Please make sure that you do put purchTable.purchId in condition statement, otherwise the SQL statement will retrieve an empty result set.
The last option, using Query
e.g.
Query query = new Query();
QueryRun queryRun;
query.addDataSource(tableNum(PurchTable)).addRange(fieldNum(PurchTable, PurchId)).value(‘!00007*‘);
queryRun = new QueryRun(query);
if(queryRun.next())
purchTable = queryRun.get(tableNum(PurchTable));
print purchTable.PurchId;
pause;
Using NotExists join seems more complicated than the first option, but actually there is no performance difference between them.
За это сообщение автора поблагодарили: alex55 (1).
Sample Design Patterns: Book Give-away: 'Microsoft Dynamics AX 2012 Development Cookbook' Blog bot DAX Blogs 1 12.05.2012 16:55
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 7 Blog bot Dynamics CRM: Blogs 0 27.03.2012 02:11
dynamics-ax: Microsoft Highlights New ERP Public Sector Capabilities for AX 2012 Blog bot DAX Blogs 0 23.05.2011 19:11
dynamics-ax: Interview with Amber Kirkman, Director of Marketing - Sunrise Technologies Blog bot DAX Blogs 0 30.09.2010 23:06
Часовой пояс GMT +3, время: 05:16.
