emeadaxsupport: Dynamics AX 2012 EP: Problem with installing Enterprise Portal " User cannot be found."
Источник: http://blogs.msdn.com/b/axsupport/ar...ound-quot.aspx
============== Couple of times we saw the issue while running axsetup.exe to install Enterprise Portal that is failing with error: Entering function CurrentUserAlias Leaving function CurrentUserAlias Creating new Enterprise Portal Site with following the parameters:\n URL: http://daxtstep.exnet.sas.com/sites/DynamicsAx\n Title: EP Site\n LCID: 1033\n OwnerLogin: CARYNT\spdax Administration Web Service URL: http://daxextst01:10000/_layouts/ep/WSSAdmin.asmx An error occured while Setup was creating a new site. Exception of type 'Microsoft.SharePoint.SoapServer.SoapServerException' was thrown. User cannot be found.0x80131600 Exception of type 'Microsoft.SharePoint.SoapServer.SoapServerException' was thrown. System.Web.Services.Protocols.SoapException at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) at Microsoft.Dynamics.Framework.Deployment.Portal.WSSAdmin.CreateSite(String Url, String Title, String Description, Int32 Lcid, String WebTemplate, String OwnerLogin, String OwnerName, String OwnerEmail, String PortalUrl, String PortalName) at Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.CreateDefaultEPSite(String virtualServerUrl) To overcome this issue we need to: Make sure that Central Administration service is running as internal user domain account. To change Central Administration account you can use following procedure (also applicable for SharePoint 2010) http://technet.microsoft.com/en-us/l...ffice.12).aspx Источник: http://blogs.msdn.com/b/axsupport/ar...ound-quot.aspx
