Старый 20.03.2013, 17:11   #1
emeadaxsupport: Tier 2 Country Labels are not upgraded During AX 2012 R2 In-Place upgrade
Источник: http://blogs.msdn.com/b/axsupport/ar...e-upgrade.aspx
This is the scenario:
You are performing an In-Place upgrade from Microsoft Dynamics AX 2012 CU3+ to AX 2012 R2, and have “Foundation Labels II” installed in the model store. After completing the upgrade you will find that the labels for Tier 2 Countries (the ones that were originally in the Foundation Labels II model), no longer exist.
There is currently a hot-fix in progress for this, however until this is released you can follow the workaround below:
  1. After removing any of the “Upgrade” models as detailed in the upgrade guide, and before running the database setup remove the additional model “Foundation Labels II” using AXUTIL.
    • Run “AXUTIL list” from a command prompt to get the model ID for “Foundation Labels II”
    • Run “AXUTIL delete /model:” to remove the Foundation Labels II” model, as in the screenshot above this would be “AXUTIL delete /model:23”
Please note, I will update this post with the hot-fix details once it is released. At the moment I don’t have details of when this will be.
emeadaxsupport: Fix for AX 2012 R2 In-Place Upgrade: Database setup error “An item with the same key has already been added” Blog bot DAX Blogs 0 20.03.2013 17:11
emeadaxsupport: Updated documentation available for in-place upgrade from Dynamics AX 2012 to Dynamics AX 2012 R2 Blog bot DAX Blogs 0 16.02.2013 01:14
Часовой пояс GMT +3, время: 20:24.
