05.07.2013, 19:12 | #1 |
emeadaxsupport: Understanding messages that appear in a RecID conflict project
Источник: http://blogs.msdn.com/b/axsupport/ar...t-project.aspx
============== Greetings all - every once in a while, when running a Best Practice Check or creating a set of Code Upgrade Projects, you may run across errors related to RecID and TableID conflicts, which really indicate failure to properly use the RefRecID and RefTableID EDTs. Here is a listing of the most common errors seen and some suggested resolutions: Conflict Message - RecId relation missing This conflict occurs when a table contains a field that uses the RefRecId extended data type (or derived type) but no relation is defined for that field. Resolution Tip -To resolve a RecId relation missing conflict, either define the missing relation or don’t use RefRecId as an extended data type on the field. Conflict Message - TableId relation missing This conflict occurs when a table contains a field that uses the RefTableId extended data type (or derived type) but no relation is defined for that field. Resolution Tip - To resolve a TableId relation missing conflict, either define the missing relation or don’t use RefTableId as an extended data type on the field. Conflict Message - Field uses RecId This conflict occurs when a table field uses the RecId extended data type. Resolution Tip - To resolve a field uses RecId conflict, you must use RefRecId or a derived extended data type and define the relation that actually uses this field. Conflict Message - Field uses TableId This conflict occurs when a table field uses the TableId extended data type. Resolution Tip - To resolve a field uses TableId conflict, you must use TableRecId or a derived extended data type. Conflict Message - Type extends RecId This conflict occurs when you create a new extended data type that extends the RecId type. Resolution Tip - To resolve a type extends RecId conflict, you have to change the extending type to RefRecId. Conflict Message - Type extends TableId This type of conflict is similar to the type extends RecId conflict. It occurs when an extended data type extends the TableId type. Resolution Tip - To resolve a type extends TableId conflict, you have to change the extending type to RefTableId. Источник: http://blogs.msdn.com/b/axsupport/ar...t-project.aspx
