19.08.2013, 19:11 | #1 |
emeadaxsupport: Intercompany time postings incomplete at transaction voucher level when project date differs from the day posted
Источник: http://blogs.msdn.com/b/axsupport/ar...ay-posted.aspx
============== In AX 2012 R2, before Cu6, the following issue occurs: project timesheets vouchers are not ok for intercompany postings. Trying to post an intercompany timesheet for projects, the system uses a wrong posting date for part of the voucher. Moreover, as a consequence, the entire posted voucher is visible only in the G/L and not in the Project inquires (refer to the attached document for details). There is not a specific KB solving this issue, however it does not occur in AX 2012 Cu6. The issue has been indirectly solved by other KB fixes: this can happen when there are a lot of fixes that insists on the same area/module . In Cu6 there are many fixes related to Project module and also specifically to the Timesheets management: Timesheet management – fixes included in Cu6 for R2 KB number Description Area 2819612 Project timesheet that is approved without required dimensions is stuck and can’t be posted SI\Project Management\Timesheet 2821270 Timesheet for on hold period with automatic posting get updated with wrong status SI\Project Management\Timesheet 2823476 Show timesheets for my projects list is displaying duplicates SI\Project Management\Timesheet 2823546 Timesheet approval action buttons are not displayed until the timesheet line is saved SI\Project Management\Timesheet 2829577 Hotfix 2829577 is available for the Microsoft Dynamics AX 2012 R2 mobile application and for the applications that work against Microsoft Dynamics AX SI\Project Management\Timesheet 2832546 Intercompany timesheets entry referencing incorrect customer accounts SI\Project Management\Timesheet 2834988 Show option in the EP Timesheet displays data incorrectly SI\Project Management\Timesheet 2840553 Timesheet internal comments are being displayed on Project Invoices rather than the External Comments SI\Project Management\Timesheet 2842012 Timesheet is submitted without error even when timesheet line does not contain line property SI\Project Management\Timesheet 2844791 Timesheet approval workflow when resubmitted after returned is assinged to the wrong approver. SI\Project Management\Timesheet Other fixes related to Project accounting included in Cu6 for R2 KB number Description Area 2823917 Posting a partial product receipt and posting partial invoice is relieving all line amounts on the committed cost when it should NOT be for a project purchase order SI\Project Accounting 2823918 Posting a vendor invoice for purchase order related to project using Retrieve purchase order functionality does NOT populate spent amount after Vendor invoice is posted SI\Project Accounting 2823919 Project Reservations for Purchase Requistion to Purchase Order to Vendor Invoice: The tax amount should not be doubled and after posting vendor invoice amount equals tax should not be left over for committed amounts SI\Project Accounting 2828155 Unable to update project related information from Excel Add-in SI\Project Accounting 2829147 Project Quotation created from Project uses Customer details (i.e. Currency) and not from Project Contract SI\Project Accounting 2829745 When disabling Feature sets related to Project and compile, you get compile errors SI\Project Accounting 2836334 Posting a project invoice the system returns the following error: "a number sequence has not been set up for the reference Invoice in the area project” ignoring the number sequence group setup SI\Project Accounting 2831336 Adjustment transactions fail when quantity is changed during adjustments SI\Project Accounting\Adjustments 2844161 Incorrect transaction types loaded on project budgets created from forecast model in case of fixed price projects SI\Project Accounting\Budget and Forecast 2844194 Invoice date of fixed price project hour forecast created from a quotation is set as session date SI\Project Accounting\Budget and Forecast 2850800 Indirect costs are not included in the Total budgeted cost field in the Cost Control form (Porting DAXSE 404712 to R2) SI\Project Accounting\Budget and Forecast 2837549 Voucher imbalance errors when posting a project elimination SI\Project Accounting\Estimates 2818805 Sales Price for hour and expense when viewed from customer is displaying sales prices for other customers SI\Project Accounting\FIM Integration 2819347 Not possible to use Financial dimension default templates on purchase order line created from projects SI\Project Accounting\FIM Integration 2823149 Allocation terms do not work properly when posting project transactions SI\Project Accounting\FIM Integration 2821222 On-account transactions which are not posted are shown as both pending and posted transactions SI\Project Accounting\Journals 2831952 Incorrect Posting type in Project Free text invoice correction postings SI\Project Accounting\Journals 2840178 Beginning balance journal causes hour qty to be incorrect SI\Project Accounting\Journals 2846373 Project validation is not working for worker/project on hour journal as it does with project quotation SI\Project Accounting\Journals 2846753 Expense Entry from Beg Bal doesn't display cost price on Project Posted Transaction SI\Project Accounting\Journals 2854552 Project Beginning Balance Journal Item transaction error requiring employee when worker/project validation set to Mandatory SI\Project Accounting\Journals 2840186 When exploding a BOM item onto a Purchase order line where the Purchase order is linked to a Project that requires Activity on items, AX throws the error: "Enter an Activity number. The require Activity number for Item transactions is marked in Project" SI\Project Accounting\Project Control 2853827 Dimension value as a selection criteria on the Project Actual transactions report throws an error SI\Project Accounting\Reports Источник: http://blogs.msdn.com/b/axsupport/ar...ay-posted.aspx
