dynamicscpm: How to import default building blocks -- Management Reporter CU6
Источник: http://blogs.msdn.com/b/dynamicscpm/...orter-cu6.aspx
============== Existing customers with reports already created in Management Reporter can also take advantage of the default reports included with Management Reporter CU6. From the Tools menu in Management Reporter, just select Import Default Reports. You'll be able to choose the reports you'd like to import. If you'd like all of them, choose Select All, otherwise pick the specific reports you want and click Import. ![]() ![]() Источник: http://blogs.msdn.com/b/dynamicscpm/...orter-cu6.aspx
