30.08.2013, 06:12 | #1 |
emeadaxsupport: Outlook Contact Field Synchronization with Dynamics AX 2012 R2
Источник: http://blogs.msdn.com/b/axsupport/ar...x-2012-r2.aspx
============== I recently ran across the need to expand fields that automatically sync from Dynamics AX 2012 R2 to Outlook contact records. It is a very time consuming and labor intense process to manually map fields on each Contact record selected for Outlook Synchronization. Here is the scenario: 1. Business Fax is not a field synchronized from AX to Outlook through standard out-of-the-box mapping. 2. By default, the Outlook Contact card displays the Primary Number selected in AX but the Business Telephone Number field is not populated on the Outlook contact form. I want the Primary Telephone to show both on the Outlook Contact card and form as the Business Telephone Number. Solution: The automatic field mapping can be customized by modifying the createFieldMapping method under the smmContactPersonSynchronizationFieldMapping table. X++: // Primary phone - modified so Primary Phone field in AX syncs to the Business Telephone on the Outlook record if (syncDirectionValid(smmOutlookContactFields::PrimaryTelephoneNumber)) { contactInfo = DirParty::primaryElectronicAddress(contactPersonEntity.getPartyRecId(), LogisticsElectronicAddressMethodType::Phone); if (contactInfo) { _contactFieldRecordMap.insert(smmOutlookContactFields::BusinessTelephoneNumber, contactInfo); } } // Business Fax - this section added so Business Fax will automatically sync with the corresponding Outlook contact field if (syncDirectionValid(smmOutlookContactFields::BusinessFaxNumber)) { contactInfo = DirParty::primaryElectronicAddress(contactPersonEntity.getPartyRecId(), LogisticsElectronicAddressMethodType::Fax); if (contactInfo) { _contactFieldRecordMap.insert(smmOutlookContactFields::BusinessFaxNumber, contactInfo); } } Of course, this may not meet your specific needs but it provides an example of what is possible through a little customization. Источник: http://blogs.msdn.com/b/axsupport/ar...x-2012-r2.aspx
