16.09.2013, 12:11 | #1 |
kamalblogs: SSRS Tip: Using labels for dynamic texts in SSRS reports – Dynamics Ax 2012
Источник: http://kamalblogs.wordpress.com/2013...amics-ax-2012/
============== Dynamic text in the reports makes them more readable and meaningful. In this article we will see how we can use labels from AX to construct your dynamic text. The string format option comes handy to help us do this. Here is how you must specify a string text with labels in it. Open the report control properties and on the property “Value”, select the expression option and place your text in the format seen here. =System.String.Format(“This is a label id converted at run time {0}”, Lables!@SYS1560); You can also use report or data base fields like Fields!CustTable.Value to construct your Dynamic text. For more tips and learning about SSRS – AX 2012 order the book Dynamics AX 2012 Reporting Cookbook authored by me. Related articles
