03.04.2014, 15:11 | #1 |
atinkerersnotebook: Copy Data From One Partition To Another Using The Data Import Export
Источник: http://atinkerersnotebook.com/2014/0...import-export/
============== Originally posted on Dynamics AX Tip Of The Day: Creating new partitions is a great way to create new instances of Dynamics AX without the overhead of creating new databases, and installing new AOS servers, because it piggybacks on the existing infrastructure you have. But it also means that you need to set up all of the data in the partition because it start’s off as a blank system… or do you? Dynamics AX has an inbuilt export and import function that allows you to export out all of the data in one partition and then import it into another. Duplication has never been so easy. View original 559 more words Источник: http://atinkerersnotebook.com/2014/0...import-export/
