littleax: How to transfer objects between server and client using List, Set or Map in Dynamics AX
Источник: http://littleax.blogspot.com/2014/07...en-server.html
============== Hi. and add pack methodSome time we use such structure as a list of classes. And we can get into situation, when we need to transfer our list using a container (for example between client and server or we need to print Excel report for client ...). In this post we will try to do this operation using very simple approach. Starting conditions. We have client site class, and hard processing. We want to transfer hard processing to the server. Let's try do something interesting ... CMSalesOrderDataContract with some variables class CMSalesOrderDataContract { SalesId salesId; Qty maxQty; Qty averageQty; } we have parm methods to access these fields public SalesId parmSalesId(SalesId _salesId = salesId) { salesId = _salesId; return salesId; } public Qty parmMaxQty(Qty _maxQty = maxQty) { maxQty = _maxQty; return maxQty; } public Qty parmAverageQty(Qty _averageQty = averageQty) { averageQty = _averageQty; return averageQty; } and simple init method public void initFromSalesTable(SalesTable _salesTable) { SalesLine salesLine; this.parmSalesId(_salesTable.SalesId); select maxOf(SalesQty) from salesLine where salesLine.SalesId == _salesTable.SalesId ; this.parmMaxQty(salesLine.SalesQty); select avg(SalesQty) from salesLine where salesLine.SalesId == _salesTable.SalesId ; this.parmAverageQty(salesLine.SalesQty); } and construct method public static CMSalesOrderDataContract construct() { return new CMSalesOrderDataContract(); } Than we have 2 classes: one collects information for us, another prints information in form; Server class collects and saves information for us. Declare variables class CMCollectInformation { List salesOrdersInfo; } init list public void new() { salesOrdersInfo = new List(Types::Class); } construct class on Server side. public server static CMCollectInformation construct() { return new CMCollectInformation(); } collect information public void collect() { SalesTable salesTable; CMSalesOrderDataContract salesOrderDataContract; while select salesTable { salesOrderDataContract = CMSalesOrderDataContract::construct(); salesOrderDataContract.initFromSalesTable(salesTable); salesOrdersInfo.addEnd(salesOrderDataContract); } } return information packed in a container public container getPackedData() { return salesOrdersInfo.pack(); } And second class allows us to print information on client side class CMPrintInformation { } initialize class strong on CLIENT side public client static CMPrintInformation construct() { return new CMPrintInformation(); } public void printInfo() { CMCollectInformation collectInformation; ListEnumerator le; CMSalesOrderDataContract salesOrderDataContract; List soClientInfoList; // create and collect information n server side collectInformation = CMCollectInformation::construct(); collectInformation.collect(); soClientInfoList = List::create(collectInformation.getPackedData()); le = soClientInfoList.getEnumerator(); while (le.moveNext()) { salesOrderDataContract = le.current(); info(strFmt('SalesId %1, maxQty %2, averageQty %3', salesOrderDataContract.parmSalesId(), salesOrderDataContract.parmMaxQty(), salesOrderDataContract.parmAverageQty())); } } Finally let's create a job to test our work static void Job3(Args _args) { CMPrintInformation printInformation = CMPrintInformation::construct(); printInformation.printInfo(); } An error is thrown, because our DataContract class does not contain pack and unpack methods Let's implment a few changes in our dataContract class Class declaration should look like class CMSalesOrderDataContract implements SysPackable { SalesId salesId; Qty maxQty; Qty averageQty; #define.CurrentVersion(1) #localmacro.CurrentList salesId, maxQty, averageQty #endmacro } public container pack() { return [#CurrentVersion,#CurrentList]; } and add unpack method public boolean unpack(container packedClass) { int version = runbase::getVersion(packedClass); switch (version) { case #CurrentVersion: [version,#CurrentList] = packedClass; return true; default : return false; } return false; } Run the job again and get a new error We need to implement create method public static CMSalesOrderDataContract create(container _packedClass){ CMSalesOrderDataContract salesOrderDataContract = CMSalesOrderDataContract::construct(); salesOrderDataContract.unpack(_packedClass); return salesOrderDataContract; } Try to run our job once again Excellent result! When we want to transfer List, Set or Map containing objects of a class between server and client we have to implement pack, unpack methods and create method. Pack and unpack methods are standard. Create method must be static and should get container as an input parameter. It should create an instance of the class, unpack variables from passed container and return the instance.Summary: Источник: http://littleax.blogspot.com/2014/07...en-server.html
