Старый 08.01.2015, 09:14   #1
25,643 / 848 (80) +++++++
mscrmblog: Filtering a Grid in a CRM 2013 Dashboard based off another Grid’s selected row
Источник: http://mscrmblog.net/2015/01/08/filt...-selected-row/
G’day Folks,
Had a requirement for a few grids on a new dashboard to be pre-filtered based off the selected row the main grid. My solution was to create a WebResource HTML page which looked at it’s parent window and set the click events on the Grid i wanted and within that click event i’d set the new FetchXml criteria to filter the second grid.
Example:
Entities
Client Entity – N:1 Outlet
Create a HTML webresource with the following:
Note:
Replace “OutletsGrid” with Grid 1 Component Name
Replace “ClientGrid” with the Grid 2 Component Name
I have a base fetchxml  (which you need to fill in) if you want to show all data before you click on any row in Grid 1
Add the Webresource to the Dashboard and Publish
My Outlet Clients Grid (Grid 2) should now filter based on the Selected Outlet (Grid 1)
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2013 Update Rollup 2 Blog bot Dynamics CRM: Blogs 0 15.04.2014 01:15
Часовой пояс GMT +3, время: 02:07.
