17.02.2015, 03:21 | #1 |
dynamicscpm: Management Reporter 2012 CU11 Hotfix 3 Now Available
Источник: http://blogs.msdn.com/b/dynamics_fin...available.aspx
============== An optional hotfix rollup is now available for Management Reporter 2012 CU11. This hotfix contains all of the bugs we have completed fixing in the last three weeks. You can take the hotfix release if there is a bug impacting you, or you can wait until there is a cumulative update available, just like previous releases. This hotfix requires CU11 Hotfix 2 (2.1.11002.5) as the base. You will need to upgrade from a prior release to Management Reporter CU11 HF2 first, then apply HF3. There is both an update to the client and the server. There are no localized files included in this hotfix, so all locales will use the same hotfix package. If you are using the Management Reporter data mart with Dynamics GP or Dynamics SL, you should disable your ERP integration prior to upgrading to Hotfix 3 to avoid bug 3373819. Do not restart your process service or enable your integration until Hotfix 3 has been applied to the server. Bug ID Title 3249707 System.ArgumentOutOfRangeException causing Process Service to stop from a scheduled report 3248432 Generating to a Report Group to Excel adds or removes formatting lines from individual reports 3214748 Issues moving Reporting Tree Definitions between folders 3373819 Generator and Designer users lose access to companies with CU11 HF2 3366638 Dynamics SL transactions incorrectly integrated as Unposted when the GLTran.Posted value contains a lowercase p 3322491 Report Designer crash issues when modifying building blocks The hotfix has been posted to CustomerSource. Hotfix 3 is version 2.1.1102.11. Источник: http://blogs.msdn.com/b/dynamics_fin...available.aspx
