emeadaxsupport: How to select all the records from a grid
Источник: http://blogs.msdn.com/b/axsupport/ar...om-a-grid.aspx
============== In Microsoft Dynamics AX 2012 not all the records are loaded when a form is opened. If a user tries to select all the records using Control + A, going to File > Edit > Select all, or selecting the checkbox left to the grid header, they will actually select only the records that are already loaded. A way to have all the records loaded and selected is to press simultaneously Control + Shift + End. A message is displayed, informing the user that all records will be loaded and warning the user that it may take a long time: ![]() I hope this is helpful! Bertrand With the help of Ankur Kumar. Источник: http://blogs.msdn.com/b/axsupport/ar...om-a-grid.aspx
