Старый 09.04.2016, 07:04   #1
arhat is offline
arhat
Angry Ошибка в запросе
Добрый день! Скажите пожалуйста почему в инвент трансе не выбирается количество,
qbdsInventTrans = query.addDataSource(tableNum(InventTrans));
    qbdsInventTrans.orderMode(OrderMode::GroupBy);
    qbdsInventTrans.addSelectionField(fieldNum(InventTrans,Qty),SelectionField::Sum);
    qbdsInventTrans.addSelectionField(fieldNum(InventTrans,CostAmountPosted),SelectionField::Sum);
    qbdsInventTrans.addSelectionField(fieldNum(InventTrans,CostAmountAdjustment),SelectionField::Sum);
    qbdsInventTrans.addRange(fieldNum(InventTrans,Qty)).value(strfmt("!=%1",0));
    qbdsInventTrans.addRange(fieldNum(InventTrans,statusReceipt)).value(strfmt("<=%1",StatusReceipt::Received));
    qbdsInventTrans.addRange(fieldNum(InventTrans,statusIssue)).value(strfmt("<=%1",StatusIssue::Sold));
    qbdsInventTable = qbdsInventTrans.addDataSource(tableNum(InventTable));
    qbdsInventTable.orderMode(OrderMode::GroupBy);
    qbdsInventTable.addSortField(fieldNum(InventTable,ItemId));
    qbdsInventTable.addSortField(fieldNum(InventTable,ItemType));
    qbdsInventTable.joinMode(JoinMode::InnerJoin);
    qbdsInventTable.fetchMode(QueryFetchMode::One2One);
    qbdsInventTable.relations(true);
    qbdsInventDim = qbdsInventTrans.addDataSource(tableNum(InventDim));
    qbdsInventDim.orderMode(OrderMode::GroupBy);
    qbdsInventDim.addSortField(fieldNum(InventDim,InventBatchId));
    qbdsInventDim.addSelectionField(fieldNum(InventDim,InventBatchId));
    qbdsInventDim.joinMode(JoinMode::InnerJoin);
    qbdsInventDim.fetchMode(QueryFetchMode::One2One);
    qbdsInventDim.relations(true);
    qbdsInventTransOrigin = qbdsInventTrans.addDataSource(tableNum(InventTransOrigin));
    qbdsInventTransOrigin.orderMode(OrderMode::GroupBy);
    qbdsInventTransOrigin.addSortField(fieldNum(InventTransOrigin,ReferenceCategory));
    qbdsInventTransOrigin.addSelectionField(fieldNum(InventTransOrigin,ReferenceCategory));
    qbdsInventTransOrigin.joinMode(JoinMode::InnerJoin);
    qbdsInventTransOrigin.fetchMode(QueryFetchMode::One2One);
    qbdsInventTransOrigin.relations(true);
    qbdsInventJournalTable =  qbdsInventTransOrigin.addDataSource(tableNum(InventJournalTable));
    qbdsInventJournalTable.orderMode(OrderMode::GroupBy);
    qbdsInventJournalTable.addSortField(fieldNum(InventJournalTable,JournalId));
    qbdsInventJournalTable.joinMode(JoinMode::InnerJoin);
    qbdsInventJournalTable.fetchMode(QueryFetchMode::One2One);
    qbdsInventJournalTable.addLink(fieldNum(InventTransOrigin,ReferenceId),fieldNum(InventJournalTable,JournalId));
    qbdsInventJournalTable.addRange(fieldnum(InventJournalTable, DKL_TransDate)).value(queryrange(dateFrom, dateTo));
    qbdsInventJournalTable.addRange(fieldnum(InventJournalTable, Posted)).value(queryValue(NoYes::Yes));
    qbdsInventJournalTable.addRange(fieldnum(InventJournalTable, JournalType)).value(queryvalue(InventJournalType::Transfer));
    qrType      = qbdsInventJournalTable.addRange(fieldnum(InventJournalTable, MEL_OperationType));
    qbdsInventLocationFrom = qbdsInventJournalTable.addDataSource(tablenum(InventLocation));
    qbdsInventLocationFrom.orderMode(OrderMode::GroupBy);
    qbdsInventLocationFrom.addSortField(fieldNum(InventLocation,InventLocationId));
    qbdsInventLocationFrom.addSortField(fieldNum(InventLocation,Name));
    qbdsInventLocationFrom.addSortField(fieldNum(InventLocation,InventLocationType));
    qbdsInventLocationFrom.joinMode(JoinMode::InnerJoin);
    qbdsInventLocationFrom.fetchMode(QueryFetchMode::One2One);
    qbdsInventLocationFrom.addLink(fieldnum(InventJournalTable, DKL_InventLocationId), fieldnum(InventLocation, InventLocationId));
    qbdsInventLocationTo = qbdsInventJournalTable.addDataSource(tablenum(InventLocation));
    qbdsInventLocationTo.orderMode(OrderMode::GroupBy);
    qbdsInventLocationTo.addSortField(fieldNum(InventLocation,InventLocationId));
    qbdsInventLocationTo.addSortField(fieldNum(InventLocation,Name));
    qbdsInventLocationTo.addSortField(fieldNum(InventLocation,InventLocationType));
    qbdsInventLocationTo.joinMode(JoinMode::InnerJoin);
    qbdsInventLocationTo.fetchMode(QueryFetchMode::One2One);
    qbdsInventLocationTo.addLink(fieldnum(InventJournalTable, DKL_InventLocationIdTo), fieldnum(InventLocation, InventLocationId));
Далее идут ренжи по типам склада в зависимости от ситуатций! Все поля в остальных таблицах находит кроме полей в InventTrans!!!
Старый 09.04.2016, 09:40   #2
gl00mie is offline
gl00mie
3,684 / 5803 (201) ++++++++++
Сообщение от arhat Посмотреть сообщение
С учетом того, как вы фильтруете выборку по InventTrans, рискну предположить, что ваши приходные и расходные проводки при группировке схлопываются в ноль. Для проверки попробуйте добавить выборку count(RecId) для InventTrans.
Старый 09.04.2016, 09:46   #3
arhat is offline
arhat
Да схлопвались в ноль! Проблему решил другим способом. Сделал проверку на склады не в запросе, но очень интересно, потому что этот запрос работал на ax 2009. а на 2012 сделал джойн InventTransOrigin в остальном все в одни в один.
Старый 09.04.2016, 10:13   #4
S.Kuskov is offline
S.Kuskov
3,440 / 1776 (66) ++++++++
Вы склады достаёте из шапок журнала? Почему не из проводок?
Старый 09.04.2016, 11:00   #5
arhat is offline
arhat
нужно делить приход и расход, через транзитный склад, получается два журнала нужно объединить в одну выгрузку и удалить проводки транзитного
запросы
Ошибка в запросе - Почему не работает?? Art_Tanis DAX: Программирование 3 15.09.2014 15:00
Ошибка в логе при установке клиента AX 2009 sao DAX: Администрирование 9 04.02.2010 11:56
Ошибка в запросе sergy DAX: Программирование 6 18.10.2005 16:38
ошибка в запросе mick_777 DAX: Программирование 3 10.07.2002 10:40
Часовой пояс GMT +3, время: 22:04.
