25.08.2009, 18:09 | #1 |
The query below combines these three queries into one:
Index Usage Query Recent Bocking History Table Information Query It can be used to just see the number of records in each table. But also by just changing "ORDER BY", it can be used to see which index cause most blocking / wait time / updates or locks. Or to compare Index Updates with Index Reads to get an idea of cost versus benefit for each index for the purpose of index tuning. So in short, one query gives you: - Index / Table Information - Index usage (benefits and costs information for each index) - Index locks, blocks, wait time and updates per read (cost/benefit). The query must be run in your NAV database. It will create a table called z_IUQ2_Temp_Index_Keys and use various Dynamic Management Views to collect information for each index into this table. First time you run it, or if you want to refresh data, you must run the whole query which may take up to a minute of two for each company in the database. After that if you just want to change sorting / get the results again, then you only need to run the last part of the query, beginning with: -- Select results The last lines suggest various "ORDER BY"s that might be useful to enable instead of the default one, which is by Table Name. Lars Lohndorf-Larsen (Lohndorf ) Microsoft Dynamics UK Microsoft Customer Service and Support (CSS) EMEA These postings are provided "AS IS" with no warranties and confer no rights. You assume all risk for your use. --use NavisionDatabase IFOBJECT_ID('z_IUQ2_Temp_Index_Keys','U')ISNOTNULL DROPTABLE z_IUQ2_Temp_Index_Keys; -- Generate list of indexes with key list createtable z_IUQ2_Temp_Index_Keys( [l1] [int] NOTNULL, [F_Obj_ID] [int] NOTNULL, [F_Schema_Name] [nvarchar] (128)NULL, [F_Table_Name] [nvarchar] (128)NOTNULL, [F_Row_Count] [int] NULL, [F_Reserved] [int] NULL, [F_Data] [int] NULL, [F_Index_Size] [int] NULL, [F_UnUsed] [int] NULL, [F_Index_Name] [nvarchar] (128)NOTNULL, [F_Index_ID] [int] NOTNULL, [F_Column_Name] [nvarchar] (128)NOTNULL, [F_User_Updates] [int] NULL, [F_User_Reads] [int] NULL, [F_Locks] [int] NULL, [F_Blocks] [int] NULL, [F_Block_Wait_Time] [int] NULL, [F_Last_Used] [datetime] NULL, [F_Index_Type] [nvarchar] (128)NOTNULL, [F_Index_Column_ID] [int] NOTNULL, [F_Last_Seek] [datetime] NULL, [F_Last_Scan] [datetime] NULL, [F_Last_Lookup] [datetime] NULL, [Index_Key_List] [nvarchar] (MAX)NULL ) go CREATENONCLUSTEREDINDEX [Object_ID_Index] ON [dbo].[z_IUQ2_Temp_Index_Keys] ([F_Obj_ID] ASC ) go CREATENONCLUSTEREDINDEX [Index_ID_Index] ON [dbo].[z_IUQ2_Temp_Index_Keys] ([F_Index_ID] ASC ) go CREATENONCLUSTEREDINDEX [RowCount_ID_Index] ON [dbo].[z_IUQ2_Temp_Index_Keys] ([F_Row_Count] ASC ) go insertinto z_IUQ2_Temp_Index_Keys SELECT (row_number()over(orderby a3.name, a2.name))%2 as l1, a1.object_id, a3.name AS [schemaname], a2.name AS [tablename], a1.rows as row_count, (a1.reserved +ISNULL(a4.reserved,0))* 8 AS reserved, a1.data * 8 AS data, (CASEWHEN(a1.used +ISNULL(a4.used,0))> a1.data THEN(a1.used +ISNULL(a4.used,0))- a1.data ELSE 0 END)* 8 AS index_size, (CASEWHEN(a1.reserved +ISNULL(a4.reserved,0))> a1.used THEN(a1.reserved +ISNULL(a4.reserved,0))- a1.used ELSE 0 END)* 8 AS unused, -- Index Description SI.name, SI.Index_ID, index_col(object_name(SIC.object_id),SIC.index_id,SIC.Index_Column_ID), -- Index Stats US.user_updates, US.user_seeks + US.user_scans + US.user_lookups User_Reads, -- Index blocks IStats.row_lock_count + IStats.page_lock_count , IStats.row_lock_wait_count + IStats.page_lock_wait_count, IStats.row_lock_wait_in_ms + IStats.page_lock_wait_in_ms, -- Dates case when(ISNULL(US.last_user_seek,'00:00:00.000')>=ISNULL(US.last_user_scan,'00:00:00.000'))and(ISNULL(US.last_user_seek,'00:00:00.000')>=ISNULL(US.last_user_lookup,'00:00:00.000'))then US.last_user_seek when(ISNULL(US.last_user_scan,'00:00:00.000')>=ISNULL(US.last_user_seek,'00:00:00.000'))and(ISNULL(US.last_user_scan,'00:00:00.000')>=ISNULL(US.last_user_lookup,'00:00:00.000'))then US.last_user_scan else US.last_user_lookup endas Last_Used_For_Reads, SI.type_desc, SIC.index_column_id, US.last_user_seek, US.last_user_scan, US.last_user_lookup, '' FROM (SELECT ps.object_id, SUM( CASE WHEN(ps.index_id < 2)THEN row_count ELSE 0 END )AS [rows], SUM(ps.reserved_page_count)AS reserved, SUM( CASE WHEN(ps.index_id < 2)THEN(ps.in_row_data_page_count + ps.lob_used_page_count + ps.row_overflow_used_page_count) ELSE(ps.lob_used_page_count + ps.row_overflow_used_page_count) END )AS data, SUM(ps.used_page_count)AS used FROMsys.dm_db_partition_stats ps GROUPBY ps.object_id)AS a1 LEFTOUTERJOIN (SELECT it.parent_id, SUM(ps.reserved_page_count)AS reserved, SUM(ps.used_page_count)AS used FROMsys.dm_db_partition_stats ps INNERJOINsys.internal_tables it ON(it.object_id= ps.object_id) WHERE it.internal_type IN(202,204) GROUPBY it.parent_id)AS a4 ON(a4.parent_id = a1.object_id) INNERJOINsys.all_objects a2 ON( a1.object_id= a2.object_id) INNERJOINsys.schemas a3 ON(a2.schema_id= a3.schema_id) innerjoinsys.indexes SI ON(SI.object_id= a1."object_id") innerjoinsys.index_columns SIC ON(SIC.object_id= SI.object_idand SIC.index_id = SI.index_id) leftouterjoinsys.dm_db_index_usage_stats US ON(US.object_id= SI.object_idand US.index_id = SI.index_id and US.database_id =db_id()) leftouterjoin sys.dm_db_index_operational_stats(NULL,NULL,NULL,NULL) IStats ON(IStats.object_id= SI.object_idand IStats.index_id = SI.index_id and IStats.database_id =db_id()) WHERE a2.type <> N'S'and a2.type <> N'IT' orderby row_count desc go -- Populate key string declare IndexCursor cursorfor select F_Obj_ID, F_Index_ID from z_IUQ2_Temp_Index_Keys forupdateof Index_Key_List declare @objID int declare @IndID int declare @KeyString VARCHAR(MAX) set @KeyString =NULL open IndexCursor setnocounton fetchnextfrom IndexCursor into @ObjID, @IndID while@@fetch_status= 0 begin set @KeyString ='' select @KeyString =COALESCE(@KeyString,'')+ F_Column_Name +', ' from z_IUQ2_Temp_Index_Keys where F_Obj_ID = @ObjID and F_Index_ID = @IndID ORDERBY F_Index_ID, F_Index_Column_ID set @KeyString =LEFT(@KeyString,LEN(@KeyString)-2) update z_IUQ2_Temp_Index_Keys set Index_Key_List = @KeyString wherecurrentof IndexCursor fetchnextfrom IndexCursor into @ObjID, @IndID end; close IndexCursor deallocate IndexCursor go -- clean up table to one line per index deletefrom z_IUQ2_Temp_Index_Keys where [F_Index_Column_ID] > 1 go -- Select results select [F_Table_Name] TableName, [F_Row_Count] No_Of_Records, [F_Data] Data_Size, [F_Index_Size] Index_Size, [F_Index_Name] Index_Name, [F_User_Updates] Index_Updates, [F_User_Reads] Index_Reads, case when F_User_Reads = 0 then F_User_Updates else F_User_Updates / F_User_Reads endas Updates_Per_Read, [F_Locks] Locks, [F_Blocks] Blocks, [F_Block_Wait_Time] Block_Wait_Time, [F_Last_Used] Index_Last_Used, [F_Index_Type] Index_Type, [Index_Key_List] Index_Fields from z_IUQ2_Temp_Index_Keys --order by F_Row_Count desc, F_Table_Name, [F_Index_ID] --order by F_User_Updates desc --order by Blocks desc --order by Block_Wait_Time desc --order by Updates_Per_Read desc orderby F_Table_Name Источник: http://feedproxy.google.com/~r/Micro...and-reads.aspx
