Старый 07.09.2016, 16:11   #1
25,643 / 848 (80) +++++++
emeadaxsupport: Find which Hot-Fixes (KBs) you have installed in Microsoft Dynamics AX
Источник: https://blogs.msdn.microsoft.com/axs...t-dynamics-ax/
With the new Microsoft Dynamics AX it is not so straight forward to determine the hot-fixes (KBs) you may have installed in your environments. So, I have created the following PowerShell script to list the fixes you have in your packages folder. Please provide me with feedback on improvement suggestions or if you find any issues... Read more
Старый 07.09.2016, 21:25   #2
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1850 (69) ++++++++
Сложно как-то. А Dynamics AX -> Addins -> Apply hotfix чем плох ?
Изображения
-ТСЯ или -ТЬСЯ ?
За это сообщение автора поблагодарили: alex55 (1).
emeadaxsupport: Final Microsoft Dynamics AX 2012 R2 Content Available! Blog bot DAX Blogs 0 04.12.2012 06:12
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
Часовой пояс GMT +3, время: 11:14.
