Старый 28.09.2017, 12:11   #1
25,574 / 848 (80) +++++++
alirazazaidi: Workflow Approve Name  in Grid Dynamics Ax 2012 R3
Источник: https://www.tech.alirazazaidi.com/wo...cs-ax-2012-r3/
Small tip, with reference at the end of post. I got small task, User want Last approval Name in grid at the result.
I wrote following code snippet as method in a required table and bind it to grid field.
display Name LastApprovalName()
WorkflowTrackingStatusTable workflowTrackingStatus;
WorkflowTrackingTable workflowTrackingTable;
WorkflowTrackingCommentTable workflowTrackingCommentTable;
UserInfo userInfo;
RecId _recId;
Name _name;
_recId=5637145391;
select firstFast RecId, User from workflowTrackingTable
    order by RecId desc
    join workflowTrackingCommentTable
    where workflowTrackingCommentTable.WorkflowTrackingTable == workflowTrackingTable.RecId
join UserInfo
    where UserInfo.id == WorkflowTrackingTable.User
    exists join workflowTrackingStatus
    where workflowTrackingTable.WorkflowTrackingStatusTable == workflowTrackingStatus.RecId
       && workflowTrackingStatus.ContextRecId == this.RecId
       && workflowTrackingStatus.ContextTableId == tableNum(MyTablelRequestTable) //PurchTable
       && workflowTrackingTable.TrackingType == WorkflowTrackingType::Approval;
if (workflowTrackingTable.RecId > 0)
    _name=userInfo.name;
else
    _name='';
return _name;
Original Code snippet is https://community.dynamics.com/ax/b/...-approved-date
Последний раз редактировалось mazzy; 28.09.2017 в 12:34.
dynamicsaxse: Dynamics AX 2012 R3 cumulative updates Blog bot DAX Blogs 0 15.03.2017 18:11
dynamicsaxse: February release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 02.03.2017 01:11
emeadaxsupport: Cumulative Update 8 for Microsoft Dynamics AX 2012 R3 now available! Blog bot DAX Blogs 5 24.11.2014 17:06
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 10:52
Часовой пояс GMT +3, время: 00:27.
