How to add a new report for a business document in D365
Источник: http://alexvoy.blogspot.com/2018/06/...-business.html
============== My colleague Rod showed it to me when I needed to add a new report to Project Invoice Proposal with billing rules to be present in Print management settings. /// /// Subscribes to print mgmt report format publisher to populate custom reports /// [SubscribesTo(classstr(PrintMgmtReportFormatPublisher), delegatestr(PrintMgmtReportFormatPublisher, notifyPopulate))] public static void notifyPopulate() { #PrintMgmtSetup void addFormat(PrintMgmtDocumentType _type, PrintMgmtReportFormatName _name, PrintMgmtReportFormatCountryRegionId _countryRegionId = #NoCountryRegionId) { avrPrintMgtDocType_ProjInvReport_Handler::addPrintMgmtReportFormat(_type, _name, _name, _countryRegionId); } addFormat(PrintMgmtDocumentType::SIProjInvoiceWithBR, ssrsReportStr(avrPSAContractLineInvoice, Report)); } /// /// Adds a report format to the printMgtReportFormat table /// /// PrintMgmtDocumentType value /// Name of the report (ie. reportname.Report) /// Description of the report (ie. reportname.Report) /// Country or default (#NoCountryRegionId) /// True if this is a system report /// SSRS report or another type private static void addPrintMgmtReportFormat( PrintMgmtDocumentType _type, PrintMgmtReportFormatName _name, PrintMgmtReportFormatDescription _description, PrintMgmtReportFormatCountryRegionId _countryRegionId, PrintMgmtReportFormatSystem _system = false, PrintMgmtSSRS _ssrs = PrintMgmtSSRS::SSRS) { PrintMgmtReportFormat printMgmtReportFormat; select firstonly printMgmtReportFormat where printMgmtReportFormat.DocumentType == _type && printMgmtReportFormat.Description == _description && printMgmtReportFormat.CountryRegionId == _countryRegionId; if (!printMgmtReportFormat) { // Add the new format printMgmtReportFormat.clear(); printMgmtReportFormat.DocumentType = _type; printMgmtReportFormat.Name = _name; printMgmtReportFormat.Description = _description; printMgmtReportFormat.CountryRegionId = _countryRegionId; printMgmtReportFormat.System = _system; printMgmtReportFormat.ssrs = _ssrs; printMgmtReportFormat.insert(); } } Then I can pick it up in Print management settings in Project module. It may be a good idea to delete records from PrintMgmtReportFormat table; all its records will be recreated the next time you open Print management form. Источник: http://alexvoy.blogspot.com/2018/06/...-business.html
