Старый 30.07.2018, 20:13   #1
25,643 / 848 (80) +++++++
d365technext: Upgrade Environment using LCS D365
Источник: http://d365technext.blogspot.com/201...-lcs-d365.html
Upgrade Environment using LCS D365.
You can upgrade your 2-Tier environment to latest build using LCS.
Step-1 Navigate to your required Environment and click on maintain.
Step-2 Now click on upgrade a popup window will appear.
Step-3 Popup window contains 3 fields to be filled.
  1. Target Environment
  2. Preferred downtime start date
  3. Preferred downtime start time
Select the Build release on which you want to upgrade your environment and provide downtime as per your feasibility then click next.
Following is the filled screen shot for your reference.
Step-4 Select application version from the new window and click next.
Step-5 Now select the database type form the next window.
Three types are available
  1. None
  2. Demo
  3. Public sector data
Step-6 select custom package if you want to deploy with this upgrade.
Step-7 Enter the email address of the persons those will notified on every action on the environment.
Step-8 select environment administrator. Only users will appear in the drop-down those have administrator rights on Project and LCS.
Step-9 verify the summary
Step-10 Now enter your Account name in the text box and click save.
Service will submit to Microsoft and they will start working on the given time window.
Please feel free to contact me if you are facing any issue during implementation of this blog.
lcs: Known Issue: Unexpected Client Error occurs on the Environment details page in LCS for Dynamics 365 for Finance and Operations on-premises Blog bot DAX Blogs 0 29.03.2018 02:28
lcs: Unable to load environment message on Dynamics 365 on-premises environments that are deployed through LCS Blog bot DAX Blogs 0 16.12.2017 06:26
lcs: Known issue: Cloud-hosted environment errors for some users Blog bot DAX Blogs 0 12.09.2014 03:25
NAV Team: Upgrade Toolkit for Upgrading Data from Microsoft Dynamics NAV 2009 R2 and Microsoft Dynamics NAV 2009 SP1 to Microsoft Dynamics NAV 2013 R2 Blog bot Dynamics CRM: Blogs 0 22.11.2013 20:00
emeadaxsupport: Writing Data Upgrade Scripts Part 1: Understanding the components of the process Blog bot DAX Blogs 0 10.02.2012 05:16
Часовой пояс GMT +3, время: 06:35.
