08.08.2018, 21:12 | #1 |
d365technext: Vendor Aging Report D365FO
Источник: http://d365technext.blogspot.com/201...rt-d365fo.html
============== Vendor Aging Report D365FO As we all knows customization in Vendor Aging report or Customer Aging report is nightmare.. The same thing i faced in previous week. when a task assigned to me to debug the vendAging Report.. Report elements I have done some research in two days on this and found the below information: 1) Using CustVendTable Map and VendTable Query : Inserting data into CustVendTransAging Table. (Referà Class : VendBalanceList :: calculateDetailsForMultiple ->> CustVendAgingCalculation à process method à insertCustVendData() method. 2) Inserting data into CustVendAgingProcessingTmp table using VendTransand VendSettlement Tables. ( Refer à Class : CustVendAgingCalculation àselectTransactions() à selectOpenTransactions() and selectClosedTransactions() methods . 3) Inserting data into CustVendAgingProcessingDetailsTmp fromCustVendAgingProcessingTmp Table ( Refer à Class : CustVendAgingCalculation à selectDetailsOfTransactions() 4) Inserting data into CustVendAgingCalculatedTmpusing CustVendAgingProcessingTmp Table and CustVendAgingProcessingDetailsTmp Tables. ( Refer : Class : CustVendAgingCalculation:Process method). 5) Inserting data into VendTmpAccountSum Table usingCustVendAgingCalculatedTmp. (Refer : Class ::VendBalanceList:insertIntoTmpAccountSum()) 6) Inserting data into VendAgingReportTmp Table (which is the main temporary table used for populating data in the report) using VendTmpAccountSumandCustVendTransAging tables.(VendAgingDP class) I would request you to debug and check the classes above and tables and that would help you get more information. Источник: http://d365technext.blogspot.com/201...rt-d365fo.html
29.08.2018, 14:00 | #2 |
Блог-инстаграм: встал, умылся, поел, справил прочие потребности, подебажил отчет
-ТСЯ или -ТЬСЯ ? |
