d365technext: Bar Code in SSRS Report D365FO
Источник: http://d365technext.blogspot.com/201...rt-d365fo.html
============== Bar Code in SSRS Report D365FO Following are the simple steps to generate Bar-Code in SSRS report. In SSRS temporary table, Bar-Code filed should be extended with BarCodeString EDT. Use font >BC C128 Narrow Field in SSRS should be well space otherwise bar-code scan will not work Using following code you can generate bar-code of any value... Example: xyzTableBuffer.BarCodeField= this.getBarcode("123456789") publicstr getBarcode(str _barCodeText) { BarcodeCode128 barcode; barcode = Barcode::construct(BarcodeType::Code128); barcode.string(true, _barCodeText); barcode.encode(); return barcode.barcodeStr(); } UAT Deployment Please feel free to contact me if you are facing any issue during implementation of the blog Источник: http://d365technext.blogspot.com/201...rt-d365fo.html
#2 |
Помогла статья, благодарю.
