How to validate filename with regular expressions
Источник: http://alexvoy.blogspot.com/2022/02/...h-regular.html
============== I took the idea from this forum https://stackoverflow.com/questions/...-under-windows We can use regular expressions to check if a given file name is valid. /// /// Validates a filename for incorrect characters /// /// /// public boolean checkFileName(Filename _fileName) { var bad = System.IO.Path::GetInvalidFileNameChars(); var esc = System.Text.RegularExpressions.Regex::Escape(new System.String(bad)); var exp = new System.Text.RegularExpressions.Regex("[" + esc + "]"); if (exp.IsMatch(_fileName)) { return checkFailed(strFmt("@SYS339524")); // The specified filename is invalid. } return true; } Источник: http://alexvoy.blogspot.com/2022/02/...h-regular.html
