09.07.2008, 22:05 | #1 |
gatesasbait: How to define a custom lookup form for an extended datatype
Источник: http://gatesasbait.spaces.live.com/B...B9F5!237.entry
============== Good morning, continuing on the topic of various custom lookup how-tos, Normally, the relation specified on an extended datatype defines its lookup method, however, it is possible to override that with a custom lookup to use automatically everywhere that datatype is used. This way, you don't need to override lookup methods on every individual forms. Create a new Form, called SalesIdLookup maybe. On the SalesId datatype, for property 'FormHelp' pick your newly created lookup form. To be simple, your lookup form should be a standard one grid, non-resizable form. In code, specify the lookup control in the init() of your form (right after super()): element.selectMode(SalesTable_SalesId); //For example, this refers to the column of your lookup that users should click on. On your lookup form's design, specify the following properties: [WindowType = Popup], [Frame = Border], [HideIfEmpty = No] Et voila, everywhere the SalesId datatype will be used, your lookup form will be automatically invoked. Источник: http://gatesasbait.spaces.live.com/B...B9F5!237.entry
Опции просмотра | |
